Sponsored by:
Sponsored by: CARiD
hks ssqv installed (issues)
Old Jan 25, 2009 | 09:05 AM
Bar's Avatar
Bar
Installed the HKS SSQV blow off valve, drove around the neighborhood and everything is fine, did some 3rd gear pulls everything works fine.
However, on uphills, under minimal throttle, aka in 5th gear just cruising the car makes me pull over and says service required.
Code is P1241
Erased codes and restarted car and it works fine everywhere again unless you are cruising on uphills. Double checked hoses and clamps and all that good stuff.
Put the stock back on and tried cruising uphill, no problems.
I know blow off valves didn't work on 8 and 9's but I've seen a lot of people run blow off valves on the 10's.
Also my blow off valve doesn't mount in the stock position, but directly to the Nisei LICP.
Any ideas?
Old Jan 25, 2009 | 09:06 AM
Pure Playaer's Avatar
I think I found the issue:
"Installed the HKS SSQV blow off valve."
Old Jan 25, 2009 | 09:07 AM
Robevo RS's Avatar
this is even better:
" I know blow off valves didn't work on 8 and 9's but I've seen a lot of people run blow off valves on the 10's."
Old Jan 25, 2009 | 09:09 AM
ak47po's Avatar
There's your problem right there. "Installed the HKS SSQV blow off valve."
Old Jan 25, 2009 | 09:12 AM
Kracka's Avatar
Since the stock BOV is working perfectly, why change it? The stock one will hold plenty of boost and won't have the negative effects on drivability.
Old Jan 25, 2009 | 09:14 AM
Smike's Avatar
This.
+1 with all others. Not a good DV for the Evo, in any platform.
DailyNews
Outlander Sport
Sep 21, 2016 11:02 PM
user 38475849
Aug 31, 2016 12:20 AM
BigWhiteEvo
14
Jul 7, 2008 06:46 PM
ecmotorsports
Feb 27, 2006 09:11 PM
Vivid Racing
Feb 26, 2004 09:16 PM
