Sponsored by:
Sponsored by: CARiD
Fluids to be changed after breakin?
Old Feb 19, 2009 | 06:08 AM
THEMEMPHISFORCE's Avatar
What else should be changed after the break in period? Transfer case, transmission, rear diff????? I am not sure other then the engine oil. Thanks
Old Feb 19, 2009 | 06:28 AM
Mj23foreva's Avatar
usually people change the oil and tranny fluid
Old Feb 19, 2009 | 06:41 AM
DarwinX's Avatar
What does the owners manual say?
Old Feb 19, 2009 | 07:19 AM
chueu's Avatar
i changed the oil but is the tranny fluid really necessary?
Old Feb 19, 2009 | 07:35 AM
dek0026's Avatar
no
Old Feb 19, 2009 | 09:01 AM
neveronlineten's Avatar
I will just be doing the oil.
You can change all the fluids if you want, but its really not neccessary. The owners manual states not to change the oil till 5000 miles I think (which is a little longer than I prefer to wait for the 1st change)? I will be doing mine at 3000 miles, and their are a ton of people that do it at 1000 miles.
Old Feb 19, 2009 | 09:20 AM
c_reber's Avatar
I changed my oil right about 1k miles, and felt like the car gained a little power. Maybe just was smoother acceleration? Ether way, I would change the oil at 1-2k miles for sure.
It's so easy to do, and probably so good for the engine because the break-in oil is full of crap.
Old Feb 19, 2009 | 09:38 AM
macPSU's Avatar
What are the recommended intervals to change the tranny and other fluids? I don't have my owner's manual handy.
Old Feb 19, 2009 | 10:17 AM
Stellar24's Avatar
^^^ 15K for severe conditions (of if you actually drive your car like an Evo) and 30K for regular.
Old Feb 19, 2009 | 10:21 AM
Ltdanish07's Avatar
I changed my oil around 3,500. Ill have to take a look in the book to see what it says. It has a nice outline about when to do things
Old Feb 20, 2009 | 04:48 PM
mangoes's Avatar
changed my oil at.. 962 miles hAHA. couldnt wait for 1000. Was planning to have my transmission fluid changed because of the notchiness at the next oil change but the notchiness has sort of gone away. Probably will have all driveline fluids changed at 15k.
Old Feb 21, 2009 | 05:03 PM
rEVOltX's Avatar
How is it so easy to change? Don't you have to jack the entire car up or get it on a lift in order to get underneath it? I'm at 1,700 miles and will be changing out my oil but just not sure how to get to it without doing the above.
Old Feb 22, 2009 | 04:35 AM
I think you just have to jack the front up, and I believe it is only a few bolts to remove the access cover and drain plug and filter are right by each other, so I have heard. The dealer is doing my oil changes for the first 37k cuz it is free ,,,,,so not sure
Old Feb 22, 2009 | 07:50 AM
Jakeg97's Avatar
usually just the oil , but you could change them all. its all personal opinion
Old Feb 22, 2009 | 07:52 AM
Jakeg97's Avatar
no, but i changed my tranny fluid on my evo at 15k miles and i was surprised how much metal shavings were on the magnetic drain plug
