Sponsored by:
Sponsored by: CARiD
Fluids to be changed after breakin?
Old Feb 22, 2009 | 09:47 AM
lacrosseks29's Avatar
i would change it if it were my car
Old Feb 22, 2009 | 11:15 AM
aftershock141's Avatar
Changed my oil at 1,153 miles.
Old Feb 23, 2009 | 08:53 PM
rEVOltX's Avatar
Originally Posted by THEMEMPHISFORCE
I think you just have to jack the front up, and I believe it is only a few bolts to remove the access cover and drain plug and filter are right by each other, so I have heard. The dealer is doing my oil changes for the first 37k cuz it is free ,,,,,so not sure
The ony problem with that I believe is the drain plug is in the front?? Jacking up the front would cause all the oil to drain to the rear of the pan which wouldn't let me drain all the oil. Anyone else have any solutions? I'm not to happy bringing it somewhere, don't trust them!!
Old Feb 23, 2009 | 10:36 PM
I Phantom I's Avatar
Getting close to 1K here... looks like it's going get a change of oil and then the fun begins...
Old Feb 23, 2009 | 11:33 PM
SpaceMonkeyAndy's Avatar
Hmmm.... maybe ramps for the front, then jack the back up to get it level again? Might be kind of sketchy though.
Old Feb 23, 2009 | 11:41 PM
cool_g_83's Avatar
I recently just changed my oil and it was quite easy. Drove it up on rhino ramps, removed the cover (10mm socket), took off oil filter, removed oil drain plug (17mm), let it sit to drain for a while, fill new oil filter w/ oil then attach to car, put oil drain plug back in w/ crush washer, fill it up and be done.
Old Feb 24, 2009 | 08:04 AM
ugakirk's Avatar
I think that im a little over 900 miles so im changing mine soon.
My driveway is sloped so i guess i'll use ramps and just count on the driveway to level out my car.
Old Feb 24, 2009 | 12:16 PM
matias04374's Avatar
I changed my cars oil at 2900.
Old Feb 24, 2009 | 12:23 PM
apagan01's Avatar
engine:
tranny and TC rear:
Old Feb 24, 2009 | 06:41 PM
THEMEMPHISFORCE's Avatar
I just had my oil changed today at 3213 with mobil 1 EP and some Lucas oil and it is already dark. I only put about 20 miles on it and it is almost black. I can't believe this.
Old Feb 24, 2009 | 07:43 PM
gizmotoy's Avatar
What did you do to clear the top of the ramp? I have a set of Rhino ramps I used for my other cars, but the front bumper on the Evo sits too low and would scrape before the tires even touch the ramp.
EvoSeanzie
Nov 19, 2024 11:48 AM
ant_evox
19
Jun 2, 2017 11:42 AM
captinnitro
Feb 24, 2016 10:03 AM
Jaxson75
Lancer Engine Tech
10
Feb 11, 2016 05:11 AM
grips03
Jul 13, 2003 06:26 PM
