Sponsored by:
Sponsored by: CARiD
Urgent~~ Need help about the head lights
Old Mar 10, 2009 | 08:57 AM
H'swwEVO's Avatar
Hi, I got my H.I.D installed on my X GSR last year, It worked fine ,just sometimes flashing when start the car.Buy now the low beams are totally not working(even I changed the stock lights back) . fog lights and high beams are fine and all the elctrical devices are fine. Anyone know what and where the problem could be??
Old Mar 10, 2009 | 09:07 AM
WWevoX's Avatar
I would start with the wireing. Depends on how they were wired and if the right gauge wire was used, the wires by the connectors could have possibly burnt. Check the connectors not just for that but water damage. I would also get a volt meter and test the power output on all the connectors and the ballast.
I haven't expierenced bad HID bulbs so I hinestly don't know what to look for to see if the bulbs had burnt out.
Good luck and hopefully its a simple fix
Old Mar 10, 2009 | 09:18 AM
tvbf1's Avatar
Did you check the fuse?
Depending on the kit that you get, the ballast can be pulling more watts and that'll blow the fuse.
Old Mar 10, 2009 | 09:23 AM
pltek's Avatar
disable the friggin drls, there is a fuse in a fuse box
Old Mar 10, 2009 | 10:03 AM
JoeyM3's Avatar
+1 check the fuses
Old Mar 10, 2009 | 10:15 AM
jmorris1027's Avatar
its not as easy as that on non sss cars. I pulled every fuse and relay in the car and in the engine compartment that had anything to do with the headlights, and either it didn't turn anything off or turned the bulbs off totally to where the headlights were inop.
Old Mar 10, 2009 | 10:49 AM
tvbf1's Avatar
Well your headlight with the HID stop working, and when you took the HID out and ran with the original setup, it still didn't work. You check the fuse and it was OK, so maybe your headlight switch is broken.
Old Mar 10, 2009 | 01:44 PM
H'swwEVO's Avatar
thx everyone for your reply.
is that means all I need to do is to check the fuse box??
cz other then that,I dun know where to look at
I checked fuse box, but I dun really know what should be "OK",and where is the switch of my headlight? SO please can anyone tell me exactly what and where to look and how to possibly fix it?? I need my head lights
Forgot to mention, fog lights, high beams,turning lights and the side signal lights are all working fine.
Old Mar 10, 2009 | 04:33 PM
Under PSI's Avatar
Put the stock headlights back in and take it to the dealer. It's under warranty isn't it?
Old Mar 11, 2009 | 02:37 PM
H'swwEVO's Avatar
That's another thing I forgot to metion. I brought my car back to the dealer for final check after the crash, and they found out the aftermarket HID, so they tole me my warranty of electrical parts are void..
Anyone knows if I brought my car to the dealer of another city? Are they going to find out my warranty was void??
