Sponsored by:
Sponsored by: CARiD
Alky Jet before Recirculation Valve
Old Mar 12, 2009 | 04:50 PM
hawaiian_evo's Avatar
This is for those who've installed an alky kit on their X's or anyone who has experince with this.
I will be installing an alky kit soon and I was wondering where did most of you tap for the jet to spray into the TB (throttle body).
The X LICP has a massive rubber hose connecting the tb and licp pipe. Right after the rubber /cylacone connector is the by pass valve. So there is no room to tap for the jet after the recirc valve.
Option #1 install the jet beofore the recirc valve. Has anyone gone this route? Whats the side affects. I pmed richard from aquamist and he stated "There is a risk spraying your engine bay with meth (open vent BOV) if it is installed before BOV."
Option #2 buy an aftermarket licp which has more room to tap for the jet after the recirc valve. Im not trying to be cheap but i really dont want to go this route reason being there isnt much hp gain I rather invest in valve springs or something else.
any opinion or advice is appretiated.
Mahalo
Old Mar 12, 2009 | 09:13 PM
TTP Engineering's Avatar
Tap after the return in the lower metal pipe before the TB. AQ kits require x2
Old Mar 13, 2009 | 01:48 AM
ok thanks ttp
bump anyone else?
