Evo X custom sunroof
Hi guys,
Just out of curiosity, would it be possible to have someone install a custom sunroof on the Evo without destroying its looks? And if so, how much would it cost roughly?
Thanks
Thanks
call around to different glass companies. I dont know about price but some will still do sunroofs.
Keep in mind that it will never be as good as a factory installed.
I worked as an auto glass installer for 7 years and I can tell you that over time they all get wind noise. Even factory ones leak, and when they break they are never the same because its impossible to get all the glass out of the tracks.
good luck
good luck
why would you buy a car like that and want a sunroof? an evo is supposed to be performance oriented, it definitely is. there's a reason the battery and the washer fluid is in the trunk. you dont want that extra weight that high up. not to mention, most aftermarket jobs are ****ty and will probably leak.
How much are you looking to spend? I'd imagine having it done right (if it's possible) is going to cost ~$2000. That's a lot of money for a seventh window. Semi-relevant story: My dad has a Pontiac beater (biggest POS ever, not even a worthy beater) with a custom sunroof and even though the install is clean, the thing still leaks when it rains and howls (wind noise) on the freeway. And more recently the motor died and it now remains permanently shut. Anyway, my point is even if you have the install done right, projects like this usually come with some baggage in the form of increased maintenance and hassle. Not to mention it more than negates the benefits of having a lightweight aluminum roof.
as for one i believe you can buy a factory one from mitsubishi that goes on the lancers and have your own shop install it, thats the way i would go. im a sunroof person, i have my own personal thing going on to have a sunroof. ill update later
Then again I don't have an aluminum roof and dont track mine.
