Sponsored by:
Sponsored by: CARiD
cleaned air filter = idle problems
Old Mar 31, 2009 | 03:59 PM
Dr..Evo's Avatar
So I cleaned my works dropin air filter today with their cleaner and oil using their directions and now I am having some idle issues. When the car is still all is well but when coasting the revs will bounce off 1k and settle at about 1600. Thats when the clutch is not depressed. when the clutch is depressed then it will sit there and bounce back and forth between 1k and 1600. Its just super annoying. Any ideas what could be happening? Should I get a new filter and maybe clean the mas?
Old Mar 31, 2009 | 04:02 PM
geardog75's Avatar
did you possibly over oil the filter causing it to coat your mass air sensor i would try wiping the mass air sensor element off carefully
Old Mar 31, 2009 | 04:08 PM
Dr..Evo's Avatar
could be. Ill get some contact cleaner (for electronics not eyes) and clean the sensor.
Old Mar 31, 2009 | 04:13 PM
chin0's Avatar
They say you should really wait 24hr "just to be safe" after cleaning to put a clean oiled filter back in but yea wipe down your mass air sensor and make sure you plug in the mass senor nice and tight because that can cause the same problem too.
geardog75's Avatar
let me know if it works good luck
Old Mar 31, 2009 | 04:39 PM
scottatyamaha's Avatar
After I cleaned my air filter I drove the car some and then came back and sprayed the sensor down with MAF cleaner to get all the oil off of it.
Old Mar 31, 2009 | 04:45 PM
Dr..Evo's Avatar
All is well now. I got in car to go pick up some cleaner and all idle problems had vanished. Maybe it just took a little time for the car to to get used to an unblocked filter again. It was pretty dirty lots of bugs and leaves. Maybe I shoundnt wait an entire year before cleaning next time
Old Mar 31, 2009 | 04:58 PM
boostin20's Avatar
Glad that contact cleaner worked out for you, woulda sucked if you had to buy a new MAF sensor.
Old Mar 31, 2009 | 06:40 PM
Frankiago's Avatar
He didn't use it. Went away on its own...
Old Apr 1, 2009 | 10:44 AM
chin0's Avatar
cheers!
Old Apr 1, 2009 | 10:48 AM
lords3t's Avatar
+1
It still could have been the sensor and the problem 'fixed itself' when it drip dried
Old Apr 1, 2009 | 11:15 AM
DarwinX's Avatar
I've had the same problem a couple times now after installing my new HKS air filter. It' seems to "self-correct" after letting the car idle in the driveway with the A/C on for 5 minutes or so.
Old Apr 1, 2009 | 11:39 AM
boostin20's Avatar
I just realized I read scottyamaha's post and thought it was DrEvo's.
Old Apr 2, 2009 | 04:37 PM
burt_reynolds's Avatar
There is and idle learning process that involves letting the car sit for 10 minutes idle right after changing your air filter. Are you guys following this procedure when cleaning/changing your filter? If you just change it and drive, then yeah, you're gonna have problems.
Old Apr 3, 2009 | 05:13 AM
DarwinX's Avatar
I remember reading a post describing the official Mitsubishi ECU idle learning procedure, but I can't find it now.
