Sponsored by:
Sponsored by: CARiD
Q for Carbon Fiber Experts
Old Apr 6, 2009 | 10:30 AM
beetle_orange's Avatar
Is there a proper way or right tool of trimming carbon fiber? is there anything that needs to be done to the new "exposed" part?
thanks for all the help.
Old Apr 6, 2009 | 10:49 AM
JoeyM3's Avatar
you can use a dremel to sand down the resin. if the fibers are exposed you might want to buy some clear resin to cover it
Old Apr 6, 2009 | 11:02 AM
EndlessRed's Avatar
depends on what you're talking about. if you're talking about raw carbon fiber, scissors will do. if you're talking about the finished, molded product, then dremel/cutting bits off with a sand disc will work. just remember to apply a good, thick clearcoat to the area you cut afterwards to seal it again.
Old Apr 6, 2009 | 11:25 AM
thanks for the initial responses. when i go to home depot they dont just sell the resin or do they? so just apply it with a paint brush on the exposed part? what do you think about applying clear silicone?
Old Apr 6, 2009 | 11:31 AM
JoeyM3's Avatar
most autoparts store should carry clear resin, not sure about homedepot
Old Apr 6, 2009 | 11:39 AM
EndlessRed's Avatar
home depot doesn't have any clear resin last i visited. but if your local one does have clear resin, then yes you can use that.
"clear" silicone is never clear - every bottle of silicone i purchased comes out a cloudy white upon drying. plus you can't get a layer thin enough - silicone is meant to be sandwiched to provide best seal. leaving it out in the open would require you to have a thicker layer, which would be obvious when applied next to carbon fiber.
Old Apr 6, 2009 | 11:44 AM
DrasticK's Avatar
fiberglass/paint/plastics stores will carry more resin than you can think of.
Old Apr 8, 2009 | 07:39 PM
monkeywinky's Avatar
or u can use a very thin layer of CA glue. we do this for rc car parts and it works really well. do a good job sanding, and then apply a very thin layer and it should run along the edge and provide a thin, clean cover. if you mess up, just wipe it before it dries and try again.
Old Apr 8, 2009 | 08:13 PM
macPSU's Avatar
So beetle, what did you wind up using to seal the trimmed area? I noticed in your other thread that you're done trimming.
Old Apr 11, 2009 | 10:15 PM
bouncintiga's Avatar
marine shops sell fiberglass repair kits and will also sell resin just fyi.
12WWGSR91
Dec 17, 2016 07:15 AM
bwanner
Jul 11, 2016 04:49 PM
vipevo9
Oct 10, 2013 07:52 AM
FlatWhite_Evo
Nov 19, 2011 05:11 PM
shiftndeesgears
Sep 15, 2009 06:52 PM
