Has anyone had dealer installed HIDs on their X
my evo came with halogens and i want HIDs(this is supposed to be part of the deal
). are there any differences to the wiring harrness etc? or is this as simple as a plug and play switch(witch it looks like...)
thanks
jon
). are there any differences to the wiring harrness etc? or is this as simple as a plug and play switch(witch it looks like...)thanks
jon
the sss headlights have an extra relay to help with the flickering. you can install an hid kit now, but you have to have them on at all times, or else they will flicker. try doing a search.
Cheaper to do a light swap with ballasts. You'll have to disable daytime running lights with a switch of some sort. On the GSR there is no relay to disable daytime running lights. DRL might have a way to switch off in the computer according to other people.
I just wired in a switch with HID bulbs and ballasts.
will be expensive for the whole housing, are you avoiding the aftermarket HID kit route? It is a simple plug in play that isn't to expensive that you could install yourself at home. Just got to find a good place for the ballasts so they are not directly next to heat or lots of vibration.
As others had mentioned, it'll cost $2000+ just to swap the non-HID headlights for the OEM HID projectors not including labor. I am certain no dealer is willing to cough up that amount of money to sell a car on its lot when they aren't making that much margin anyway on the EVOs (unless you way overpay).
