Sponsored by:
Sponsored by: CARiD
Quick Oil Drain Valve
Old Nov 11, 2009 | 07:22 AM
dpalo's Avatar
Originally Posted by wiretap
if you're lazy as hell and want to add another possible point of failure to the car. I'll take the extra 30 seconds with a socket drive.
totally agree
Old Nov 11, 2009 | 09:10 AM
sdelivery's Avatar
http://www.westernfleet.com/femco.html
At my work, We use those on all of our fleet trucks, and all of the employees on their own cars (except me cus of the oil temp sensor on mine) They work great and dont leak at all.
Old Nov 11, 2009 | 11:32 AM
RayH's Avatar
I have one with an optional spring clip which makes it pretty much impossible for the valve to open on its own without the clip failing also.
Old Nov 11, 2009 | 01:56 PM
jwoodzx7r's Avatar
ditto, had one on my STi for 2 years with no problems whatsoever. Really quick and makes draining the oil more cake than it is already.
Old Nov 11, 2009 | 04:58 PM
JoeyM3's Avatar
also if you overfill you can drain a little out without having all the oil gush out and waste it lol. . . .found that out today had to drain a little
Old Nov 11, 2009 | 05:14 PM
Ginglingston11's Avatar
Originally Posted by endGameXIII
i think a lot of people are neglecting the fact the crush washers aren't just available from .
plus you can upgrade the crush washer to a reusable hard washer.
^^^and this is why your the only one in this thread that wants to buy one
do you realize that a hard washer will NOT do the job of a crush washer...that i mean is seal the plug from leaking!!!
Old Nov 11, 2009 | 05:21 PM
EVO_MERLE's Avatar
I too would worry about the car running out of oil because it came open with my knowing. I will just take the time to pull the bolt and replace it.
Old Nov 11, 2009 | 05:34 PM
EndlessRed's Avatar
i also realize you're ignorant. go ahead, try it. you haven't? oh okay, then read up on "solid gaskets," because apparently you don't have a clue what it is.
Old Nov 12, 2009 | 01:38 PM
►EvolutionX◄'s Avatar
So much hostility on this forum.. haha
Old Nov 12, 2009 | 02:41 PM
Ph3n1x's Avatar
For woman or girlie boys who cant turn a wrench. lol
Old Nov 12, 2009 | 03:35 PM
lex08gsr's Avatar
I would rather get burned with hot oil then use that!!!
Old Nov 12, 2009 | 03:52 PM
LaXGSR's Avatar
LOL. I agree about not introducing another potential point of failure. Plus, the oil gushes out in a steady stream when you pull the drain bolt...not sure if using the valve could leave more sediment at the bottom of the oil pan that might normally get flushed out a little better.
Old Nov 12, 2009 | 04:05 PM
eling99's Avatar
Originally Posted by EVOheaven
Hey Guys,
Has anyone purchased a valve from here? If so which part number is for our cars?
http://www.quickoildrainvalve.com/De...p?Redirected=Y
It looks like a pretty helpful tool when changing oil.
its the f-106. Size 14mm-1.5 Thanks for this post.. I might order one too!!!
Old Nov 23, 2009 | 09:46 PM
bouncintiga's Avatar
bought some stuff from my local mitsu dealer and got 5 free crush washers. free wins.
but i wouldn't be worried about something hitting it and banging it open accidentally causing an oil spill, there's the plastic cover in place which sort of prevents most of that. you'd have to hit something really bad to do any damage and by then you might've broken something worse than that ie: oil pan.
Old Nov 23, 2009 | 09:56 PM
SyZyGy1394's Avatar
Wow some dealers charge for crush washers? Heck last time I asked for 2 washers the guy gave me like 20. And they charge $4.61 for an oem filter.
