Evo X Side Mount Bracket Hardware
Hi guys,
I've just installed my side bracket for my plates and I was wondering if you knew the size/type of screws to secure the plate/frame to the bracket.
I should have researched it before I mounted, but the best that I could do was to unscrew one of the rear plate screws to test and it wasn't wide enough.
Any suggestions?
Any suggestions?
found the answer.. i was looking at the two rectangular recesses in the bracket and completely overlooked the two smaller holes that lined up PERFECTLY with my Cali plates (which I only lined up outside of the local AutoZone).
long story short, it's a 1/4" screw with wide threads so it can carve out it's own thread track as you screw it in.
