Sponsored by:
Sponsored by: CARiD
O2 Sensor Necessary??
Old Jan 10, 2010 | 09:43 PM
iEvoX's Avatar
When installing my test pipe the 02 sensor wouldnt come off.. I used an O2 socket and other tools etc.. I ended up cutting the cable and tucking neatly under the car. I have the check engine light on right now obviously but once I get a tune will it go away? Thanks for any info on this
Old Jan 11, 2010 | 09:17 AM
El_Kameleon_G's Avatar
You need it. It reads the air & fuel mixture and sends the info back to the computer to make adjustments to other sensors to keep your a/f where it needs to be.
Old Jan 11, 2010 | 09:23 AM
therocket's Avatar
I think the OP is talking about the POST cat sensor. Post cat sensor is mainly used for cat efficiency diagnostic, so if you want you can remove it and eliminate CEL using an emulator or disabling this DTC in the ECU if you find the right place into the ROM.
Old Jan 11, 2010 | 10:12 AM
iEvoX's Avatar
Yea thats what Im talking about. Thanks rocket
Old Jan 11, 2010 | 11:46 AM
mlomker's Avatar
The last I heard was that the disable hasn't been found for the X. You'd get a better answer in the ECU forum, though.
EVOREZ1992
Feb 7, 2015 04:16 AM
Jav53_evoix
Aug 5, 2014 03:30 PM
vxevolutionxv
Sep 2, 2008 05:14 PM
evilevo22
Feb 27, 2007 01:39 PM
krnzzang84720
Lancer Engine Tech
14
Apr 13, 2005 09:44 PM
