Removing the spare tire - thoughts?
You're good. Probably wont ever use it. Make sure you have practice using the plug-kit and test out the compressor
I have the same setup, still haven't gotten around to actually putting it in the car.
I'm not taking a stance either way, but Fix-a-Flat seems to believe their formula doesn't screw up your TPMS.
http://www.fixaflat.com/products.asp?page=1_0
"Fix-A-Flat® is a simple solution to a flat tire. It seals and inflates in minutes! Just connect the hose, inflate, and you will be back on the road in minutes. Shouldn't everyone carry a can of Fix-A-Flat® in their vehicles, just in case?
Safe for tire sensors
Requires no tools or jacks
Non-flammable formula
Safe to store in your vehicle's trunk or tire well
Rubber compound provides an emergency seal on contact
America's #1 tire inflator and sealer "
acid7711
May 25, 2016 09:22 AM
Kevin Koszarek
10
Oct 14, 2015 11:15 AM
