Sponsored by:
Sponsored by: CARiD
My EVO-X MR ate my Tires!!
Old Jan 30, 2010 | 08:39 AM
Lefty-EVO-X's Avatar
Hi everyone,
I have a small problem. My 08 MR ate the tires ( inner most tread blocks) on all 4 tires in like 6,000 miles. I know this is a camber issue, but I have the factory installed Eibach springs and bilstein Struts. It seems as if the Dealer did not align the car upon delivery . I believe the Yokhamas have a tread wear of 180, but I should get at least 10,000 miles out of them. I rotate the tires every 3500 miles, So I got one rotation in. I'm trying to figure out if I should turn a warranty claim.
My Question is Anyone else having this problem? Also how many miles are you avg out of the Yoko tires?
Thanks in advance for any help!
Happy Tuning
Lefty
Old Jan 30, 2010 | 08:41 AM
mlomker's Avatar
MANY people have had this problem. I doubt that the dealers even align the cars. I lost the outside edge of my tires...burned them up with less than 2k miles on the car by spending a couple hours at the track.
You'll find other lengthy threads on this topic.
Old Jan 30, 2010 | 08:44 AM
mrMTB's Avatar
at 6k miles you're not likely to get MMNA to cover these under warranty. When you do replace your tires, get a good alignment and rotate your tires a little more frequently. My first set of Advans lasted about 11k miles, while my second - on a dealer alignment - lasted only about 6.5k.
Old Jan 30, 2010 | 08:49 AM
MR. Tim's Avatar
Originally Posted by Lefty-EVO-X
Hi everyone,
Happy Tuning
Lefty
Ya alignments are super aggressive (or junk depending on how you look at it) from the factory. Chances are even if the dealership you bought it from did indeed check the alignment, it would probably show up "within limits" set by the factory. You can try to claim warranty, but they will more than likely deny you. I tried myself and got denied. I have about 4500 miles on my car and mine are already wearing uneven. Your best bet may be to get it properly aligned by Mike @ Baierl in Wexford and save up for some new tires. You should stop into the Pittsburgh Thread. There are quite a few of us around Greensburg
Old Jan 30, 2010 | 09:09 AM
lousEVOxmr's Avatar
dont cry its not a miata,
mine lasted from oct 08 until dec 15th 7200km , lol
Old Jan 30, 2010 | 09:24 AM
lowkey's Avatar
Registered User
Likely to be more a toe issue. Zero to very little toe-in seems to work best for long life. This and brake squeal is the most common complaint, btw.
Old Jan 30, 2010 | 10:17 AM
ikt's Avatar
ikt
i was down to 20% at 7500 miles
legendr34
14
Jan 16, 2014 07:45 PM
Lefty-EVO-X
10
Jan 27, 2010 04:40 PM
Nathan0490
31
Oct 1, 2008 05:36 PM
rollinonez
11
Dec 18, 2007 08:37 PM
Rcebowl
24
Jun 20, 2007 03:32 PM
