Sponsored by:
Sponsored by: CARiD
First serious problem with the X
Old Feb 6, 2010 | 10:31 PM
mdevo84's Avatar
Originally Posted by jk68x3
as just reading through this i would recommend taking off the ssqv bov. i dont have any specific quotes but i have read about people having problem with them and causing cel the traction control to kick. if u hit 22ish lbs of boost the car on factory tune may go into limp mode.
+1!!!!!!!!!! I had that BOV and it messed up a lot of things on my car. Are you VTA or recirc?
Old Feb 7, 2010 | 02:07 AM
11XRAY's Avatar
tune pls
Old Feb 8, 2010 | 09:23 AM
timbo299's Avatar
you need a tune I hade a similar problem where my car would get that light and it would go into limp mode. I called AMS they were more than helpful pointing me toward Ivey tune in Northern NJ. he took care of me and I havnt had a problem since. Good luck
Old Feb 8, 2010 | 09:27 AM
chidevildog's Avatar
tune! problem solved
Old Feb 8, 2010 | 09:38 AM
shizblam's Avatar
I don't think you have a 'serious problem'... I agree that you just need a tune.
Old Feb 8, 2010 | 06:39 PM
monkey_187's Avatar
If you dont have a recirculating setup that might be part of the problem. You should take everyones advise and get a tune to see if that fixes it. If you dont have the setup for the VTA I would either change it or get the setup. Most guys just want it for the swoosh sound, I think its just ricey for me.
Old Feb 8, 2010 | 11:20 PM
got_em's Avatar
Thats what AMS said too, good point
Old Feb 9, 2010 | 08:25 AM
WickedX1's Avatar
ov3r boost
Originally Posted by got_em
I gave my car wide open throttle last night and the "Service Required!" light came on. It always does this at WOT. I talked to AMS and was told it's a Over Boost issue or something wrong with the Diffs. I have a HKS SSQ BOV, AMS down pipe, test pipe, and single tip exhaust, Injen intake. Has anybody had this happen to them? What was it? Any ideas? I plan to go back to stock other then the down pipe and go to the dealer, Perhaps its time for a dyno tune?
overboost /torque limit exceeded
i had this problem sometimes when its very cold out i over boosted to almost 30 psi, and im on stock solenoids with just a ams turboback ams reflash and intake, A Dyno tune will fix the issue
Old Feb 9, 2010 | 09:07 AM
ikt's Avatar
ikt
it's your blow off valve, mine did the same thing when i was vent to atmosphere and it was cold.
Covered here:
https://www.evolutionm.net/forums/ev...limp-mode.html
Old Feb 9, 2010 | 01:14 PM
got_em's Avatar
Covered here:
The thing is,my car does not go limp. It drives fine, no bogging down, nothing. The only problem is the lights and I cant turn the ASC back on.
Old Feb 9, 2010 | 01:20 PM
gotrnet's Avatar
check the fluid level in the trunk reservoir. if it is low it will kick off the traction control while NOT throwing a check engine light.
Old Feb 10, 2010 | 03:43 PM
08 Evo X MR's Avatar
bro its just an over boost problem, dont check ur trunk reservoir or anything, just go get ur car tuned and get a boost controller.
cheers and happy modding
Old Feb 11, 2010 | 02:48 PM
got_em's Avatar
Well, got my car tested and its over boost but I will not be able to get it tuned till spring. This cant hurt my car right?
Old Feb 11, 2010 | 03:18 PM
Noize's Avatar
EvoM Administrator
What exact code?
Old Feb 11, 2010 | 04:24 PM
got_em's Avatar
I'm not sure what the code is, I didn't get a print out of the scan or anything. I believe it was the code you mentioned earlier, the numbers look familiar. The only thing with that is that the car usually goes limp with that code and that doesn't happen with me. The good thing I was told is to have the tuner disable the DTC when I get the car tuned and the problem will be solved.
