Sponsored by:
Sponsored by: CARiD
Turbo whine/screech
Old Feb 27, 2010 | 07:46 AM
evo unknown's Avatar
My Evo 8 has a turbo whine, but it's normal, some have it some don't. I checked and no shaft play.
Simply take it to the dealership and tell them your concern, if it is normal they will at least put my mind at ease.
Old Feb 27, 2010 | 08:36 AM
Noize's Avatar
EvoM Administrator
Originally Posted by Xtremist
If you want to quiet your engine down I suggest using Royal Purple oil, it makes even the loudest lifter knock livable!
This is one huge thing I do not miss about the 4G63!
Drive through lady: "Can I take your order?"
Me: "TAP TAPould TAP TAPlike TAP TAP TAPber TAP TAPhree TAPlease"
Drive through lady: "You must have an 4G63."
Old Feb 27, 2010 | 09:05 AM
KPerez's Avatar
If it truely just is a sound issue, just put on an AMS CBE...then U won't hear anything but the exhaust note.
Later, Ken
Old Feb 27, 2010 | 11:19 AM
Xcogg's Avatar
a winding/siren noise that seems to follow to the tune of our turbo spooling. It sounds like an electrical frequency
Yea I get this noise too through the speakers when I'm charging my ipod and playing it at the same time. But this is definitely coming from up front.
Old Feb 27, 2010 | 11:53 AM
MY08GSRX's Avatar
seems like an electrical grounding issue to me....
OP: can you elaborate further on this
Old Feb 27, 2010 | 12:00 PM
macPSU's Avatar
I occasionally get the same whistle/whine noise as you. Seems to only happen when weather is colder. I've narrowed it down to about 3-4k RPMs in 3rd and 4th gear, at about 10psi.
Old Feb 27, 2010 | 04:31 PM
Noize's Avatar
EvoM Administrator
Man, that is mine... bang on exact.
Old Feb 28, 2010 | 09:49 AM
wild01ride's Avatar
Sounds like some kind of harmonic with the impeller.
Old Aug 3, 2010 | 08:55 PM
popdakebin's Avatar
I want to bump this. Been getting a loud whistle sound that is at the same tone. The loudness of the whistle may vary, but the tone is the same. Kinda like when you blow on a blade of grass. When I accelerate at 3/4 throttle, the noise will come noticable and for sure it is not the turbo spool. The turbo spool isn't as loud as this.
Old Aug 29, 2010 | 12:03 AM
futurevowner's Avatar
Does it do it louder in higher gears?
Old Aug 29, 2010 | 12:31 AM
Steve Hischar's Avatar
I drove mine up to PA, from FL. And while I was at the 10 hour mark or so of straight driving, whenever I would start to spool, even the slightest bit, I would hear a high pitched noise. I think it was just to hot out, then it started raining and the sound went away in a couple minutes.
anthonyrb98
19
Sep 5, 2019 05:14 PM
djsoprano
May 28, 2016 02:15 PM
steinvb12
13
Jun 15, 2014 11:39 AM
total0wnage
Jul 1, 2013 01:00 PM
jrank3792
Feb 4, 2012 11:55 AM
