Sponsored by:
Sponsored by: CARiD
Turbo timer harness, NO GOOD?
Old Mar 5, 2010 | 02:50 PM
EvoXcrzy08's Avatar
I have a greddy turbo timer. i also bought the harness to make this a plug and play. the problem is the the stock harness uses 4 wires. my turbo timer harness uses 6wires???? anyone have any issues? 08 evo x gsr
Attached Thumbnails Turbo timer harness, NO GOOD?-img_0107.jpg   Turbo timer harness, NO GOOD?-img_0108.jpg
Old Mar 5, 2010 | 04:07 PM
Bullo's Avatar
Have you already plugged it?
Does it work?
Old Mar 5, 2010 | 08:48 PM
Brokenevo's Avatar
yeah i got the same thing it seems way too much
Old Mar 5, 2010 | 09:58 PM
EvoXcrzy08's Avatar
Yes plug it all in. Turn the key off and it work. Please understand that I only start the car for 1min and turn it off. The turbo timer kept the car on for like 5mins. Even when I turn off the turbo timer it keep running??? I had to unplug the harness to turn off my evo? Will check wiring tomorrow to see which ones I need and maybe fix this problem. I will post alot of picture so it helps those that may run into this. But has this happen to anyone?
Old Mar 5, 2010 | 10:09 PM
boostless's Avatar
I just installed a GReddy turbo timer with their turbo timer harness on an Evo X on tuesday. The harness does work. Make sure that your e-brake wire is tapped in and the ground is secured properly.
Old Mar 5, 2010 | 10:20 PM
EvoXcrzy08's Avatar
Did you harness look like mine? And I didn't hook up the e-brake wire due to the fact I only thought it didn't need it for it to work.
VtexGt3
Sep 3, 2015 11:28 AM
filter
Dec 22, 2006 10:33 AM
redevo561
Jun 4, 2005 11:26 AM
Whendidieatcorn
Jul 10, 2004 11:01 AM
Option2
11
Apr 17, 2003 07:14 AM
