Sponsored by:
Sponsored by: CARiD
Does the X have an "integrated roll cage" like the earlier Evos?
Old Mar 11, 2010 | 05:05 PM
Noize's Avatar
EvoM Administrator
Originally Posted by Robevo RS
the X body is supposedly much safer then any other evo before. That is why we pay the weight penalty ...
While the X is substantially stiffer than all the prior chassis, its not heavier only because of that. Its mainly heavier because its a platform share with much larger vehicles and it just flat out larger in all dimensions. I know you know this already, Mr. Rob, just posting it for others benefit.
Old Mar 11, 2010 | 05:15 PM
Roberti22's Avatar
^^^this is totaly off subject but that is a IV in your Avatar....i like the fact that the X is bigger im deff looking into them when i get back to the states
Old Mar 12, 2010 | 07:46 AM
weneversleep's Avatar
Originally Posted by St1g
as for the op's question, "would it be safe to have fixed-back seats and harnesses in an Evo without a cage?" all the discussions i've ever read from track gurus suggest that this is a very bad idea. and given that some posted above that they've seen evos actually crushed when flipped, well, i guess that's that then. besides, your seats already have harness holes, and are relatively bolstered, full buckets probably will not hold you too much better if your harnesses are on tight enough. i know in my vette, even with those lame useless seats it has stock, with harnesses i can hardly move (not that this was a brilliant idea either with the stock seats.)
Believe me, I understand the safety consequences of not having a bar/cage when you have fixed-back seats and harnesses. I cringe every time that I see this setup, and I will refuse to instruct in a car setup like that.
I now teach classroom for various track organizations, and I talk about how the car was designed as a complete safety system. If you change one piece of that system, the entire system is compromised.
I'm just trying to figure out if the Evo is strong enough (NOT stiff enough, as this discussion has seemed to devolve into--two different things) to not require a bar/cage with fixed back seats & harnesses. In other words, would the roof collapse onto a driver rigidly held in his seat, as it would in most every other stock car, or did they construct the Evo with some kind of integrated roll cage? I still haven't heard a satisfactory answer yet.
Honestly, I'm thinking the answer is now "no", given statements such as "I've seen Evos with their roof caved in".
Old Mar 12, 2010 | 08:00 AM
Robevo RS's Avatar
And you did a great thing , posted to educate for other people benefits.
Old Mar 12, 2010 | 08:07 AM
ScottSpeed21's Avatar
There is no integrated roll cage. The chassis is well reinforced, yes, but more for overall chassis stiffness for handling purposes, not as rollover protection.
If the car flipped would the roof cave in on the driver? Depending on how hard it landed on the roof, I would assume yes.
Old Mar 12, 2010 | 11:23 AM
Robevo RS's Avatar
hm if you do it right as my Hungarian friends do it, it will cave in.
this the result of one Hungarian test drive.
Old Mar 12, 2010 | 12:19 PM
evolvedx's Avatar
Guess he didn't stick the landing.
Old Mar 12, 2010 | 01:06 PM
eddie's Avatar
The B pillars on the X use 3 full layers of stampings stacked on top of each other for increased side intrusion protection while the roof structural beams use 2 layers. The Evo VIII-IX use 1 layer each.
Old Mar 15, 2010 | 09:15 PM
AFD's Avatar
AFD
Lol.. I hope he ducked or something, ouch!
nick735
Oct 20, 2007 01:44 PM
Paul Nelson
May 9, 2007 08:57 AM
wi_whoami
May 17, 2006 03:30 PM
EVO-Bill
Nov 8, 2003 12:19 PM
