Sponsored by:
Sponsored by: CARiD
heavy backfire
Old Mar 26, 2010 | 11:05 PM
Freeman 702's Avatar
Found the problem today...the vacuum hose to the fuel pump was not tightened and installed correctly. Creating the boost pressure to backfire. Sooooo after 2 days of downtime my baby is back running at a 100% thanks for all the inputs though people.
Old Mar 26, 2010 | 11:36 PM
evo=ms3killa's Avatar
Good to hear. My evo does that too once in awhile I'll check my fuel pump tomorrow thanks for the info.
Old Mar 27, 2010 | 08:28 PM
evolv's Avatar
Could you take a pic of the connection you're referring to?
Old Mar 28, 2010 | 12:14 AM
I can take a pic of the mechanic paper with what they found wrong. Ill do it first thing in the morning. I honestly could not tell you which hose. The paper has a short description on it. Hopefully you can decipher it and it will help you
Old Mar 28, 2010 | 02:50 AM
BigT's Avatar
Probably was the hose going to the fuel pressure regulator. My car did exactly what you're describing when mine blew off.
Old Mar 28, 2010 | 08:07 PM
JDZNate's Avatar
Veteran: Air Force
Glad you got it fixed.
Old Mar 28, 2010 | 09:10 PM
Yes sir, that's exactly what it says. " found loose vacuume at fuel pressure regulator; repaired connection at vacuum line at fuel pressure regulator"
Hope this helps. And its easy to test, go 30-35 MPH, put it fifth, and stomp it to the floor andsee what happends.
jorge mr
22
Nov 9, 2018 05:05 AM
wacboyjulian
Mar 5, 2014 10:08 PM
ScoobehDoo
Sep 11, 2013 05:17 AM
Pssst
Mar 5, 2012 07:35 PM
David Buschur
53
Mar 21, 2008 08:42 PM
