Sponsored by:
Sponsored by: CARiD
exhaust leak cant fix
Old Mar 30, 2010 | 12:46 PM
David Fogleman's Avatar
Ok so I got under my car Yesterday because i had a exhaust leak and it was driving me crazy! It was leaking from my test pipe to the Y pipe connection. I unbolted and tightened it very tight. It somehow got worse and its still leaking from the same spot. I have been told to use high dollar gaskets, but it just doesn't make any since. The Exhaust is the new agency power turboback. If anyone has any imput whatsoever i would appreciate it. i gotta get rid of this annoying sound!! thank you
Old Mar 30, 2010 | 12:52 PM
Freeman 702's Avatar
JB weld if you plan on never taking it off. Or r2 the gaskets and ops check that beast
Old Mar 30, 2010 | 12:56 PM
Ryuartz's Avatar
Try RTV Silicone gasket maker. Make sure buy high temp(Ultra Copper) one.
Old Mar 30, 2010 | 03:55 PM
Madrican's Avatar
I had a exhaust leak between my AMS HFC and HKS HI-power exhaust. As your problem, I tighten it and didn't solve anything. When I double the gasket between the connection it solve my problem. Maybe it will work for you.
Old Mar 31, 2010 | 08:29 AM
thank you i will try the double up gasket first.
Old Mar 31, 2010 | 08:46 AM
K1tt3n5's Avatar
flange on one could be warped.
Old Mar 31, 2010 | 09:19 AM
Finest's Avatar
Either double up on the gasket or shave the surface of the flanges so they're true and flat. The flanges can warp due to the heat from welding.
BOOSTINAT30PSI
24
Feb 8, 2017 07:48 PM
elhalisf
36
Nov 19, 2012 02:06 PM
storm_trooper
19
Jul 14, 2010 10:23 AM
LV///R
Oct 4, 2009 06:58 AM
deegaw11
May 13, 2007 07:06 PM
