Sponsored by:
Sponsored by: CARiD
Warm/cold/hot start issues... anyone else?
Old Apr 8, 2010 | 01:44 PM
HybridKOOP's Avatar
When my car stock (for only 500 miles), it started fine.
I then went to Injector Dynamics 1000cc's with a tune, FP Red, etc... and the car RANDOMLY would turn over for like, 10 seconds sometimes before decided to start. I'd normally get a black cloud of barely burnt fuel when it DID start.
I switched to DW1000cc's, and still have the same issue. Sometimes it does it when it's cold, sometimes, warm, sometimes hot. I think it tends to do it more when it's already warm.
Does anyone else have similar issues? Sometimes, the car starts first crank. Others, it takes 20 or more cranks to finally fire up. Bottom line: it's embarrasing.
I am thinking maybe I need to adjust latencies or fuel injector scaling in the COBB AP. Anyone else have anything other than that to check out?
BTW, I am running the latest "blue" fuel pump relay...
Lou
Old Apr 8, 2010 | 01:48 PM
EVO Nate's Avatar
I have experienced the same here, with FIC 1050's. Doesn't really matter the weather, sometimes it just won't crank. I too believe it may have to do with proper or IMPROPER injector scaling, maybe someone with experience could shed some light?
Old Apr 8, 2010 | 01:55 PM
HybridKOOP's Avatar
Glad to know I'm not the only one. Do you drive an EVO X? Just asking because you have an 8/9 in your avatar.
And yes, I think it may be latencies as well, but why does it start perfectly sometimes and feel flooded/rich at others... hmm.
Lou
Old Apr 8, 2010 | 08:38 PM
DJ Christian's Avatar
If it makes you all feel better, my Lancer GTS does this at complete random. Did it today, in fact. I usually crank for 3-5 seconds, stop, crank again and lightly apply gas and it starts right up.
Old Apr 8, 2010 | 08:59 PM
wiretap's Avatar
Pretty normal.. I get the same occurrence every so often. There's other threads on the same issue. I've had all my recalls taken care of.. but the issue still remains. It will probably get figured out and recalled two years from now or something. =/
Old Apr 9, 2010 | 10:49 PM
tephra's Avatar
did you tuner play with the cranking enrichment table?
Old Apr 10, 2010 | 03:07 PM
lowkey's Avatar
Registered User
Cobb specifically states DW800CC for their maps
Yes
Old Apr 13, 2010 | 07:25 AM
HybridKOOP's Avatar
No. I just opened my map compared to a stock map, and this table is identical between the two. I think you're onto something (as usual), Tephra.
I'd imagine that a smaller number than stock on this table would suggest a shorter time period to open injectors on cranking? Obviously I'd want to do this as I'm running 1000cc injectors... Any inputs appreciated.
Lou
Old Apr 13, 2010 | 07:43 AM
HybridKOOP's Avatar
Yes
Specifically states what?
Old Apr 13, 2010 | 07:45 AM
tephra's Avatar
E85?
if not, then you can multiple the cranking enrichment table by your injector scaling..
ie stock = 532
dw1000's = 900???
532/900 = 0.6... so multiple all the cranking enrichment data points (not the axis) by 0.6 and try that...
evo360bhp
May 28, 2017 01:41 PM
evo.matt
May 20, 2017 09:01 PM
mctonyb
Sep 11, 2016 09:41 PM
Hotsauce101
Nov 18, 2015 11:35 AM
EriCS
Jun 5, 2010 03:50 PM
