Sponsored by:
Sponsored by: CARiD
how big is Evo X's reserve tank?
Old May 3, 2010 | 12:35 AM
  #46
JED_POLAND's Avatar
In my car the "reserve" means 10 to 12 liters which is about 2.9 gallons.
My everyday urban consumption is 24 liters per 100km (9mpg) which is same as my V8 H.O. 4.7 Grand Cherokee.
If I think what I do I am able to go down to 18 liters per 100km (13mpg).
Once I really wanted to check how low I can go and I made 13 liters per 100km (18mpg).
The lowest consumption I ever recorded was 10 liters per 100km (23mpg) - cruise control engaged for 50 miles @ speed of 55 mph.
I someone is concerned about the fuel consumption should never buy car like Evo/Sti and likes.
Old May 3, 2010 | 12:37 AM
  #47
tephra's Avatar
24/100 is TERRIBLE.. something is wrong with that...
I average 12L/100
are you using 98RON (93oct?)
Old May 3, 2010 | 12:38 AM
  #48
JED_POLAND's Avatar
Originally Posted by bouncintiga
correct. but it's not worth the cost of buying and installing to save on gas. unless you're concerned with the environmental impact of burning more gas (but then the evo wasn't the best choice in car).
If you ask me, the only reason to buy it is to lower the noise inside the car at higher speeds.
I will never ever understand why they have not made a 6th gear. It is crazy.
Old May 3, 2010 | 12:40 AM
  #49
JED_POLAND's Avatar
I average 12L/100
Yep, I am using 98.
Maybe there is something wrong the map? It is slightly tuned to 333 flywheel HP.
If we talk about average I could say 18 if I drive for more than 15-20km.
Old May 3, 2010 | 01:14 AM
  #50
Antarius's Avatar
Originally Posted by injenevox
i drive mostly high way but after i got the injen intake and ttp tune, i went up in gas miliage?? i was always at 26-27 highway and now 31-32 is that common? i mean i like it and all lol
Yes, it's very common, since our cars run very rich with the factory tune.
"Tuning" the car means using the "correct" amount of gas and air for each combustion cycle...
and "correct" means less than stock.
Old May 3, 2010 | 02:23 AM
  #51
JED_POLAND's Avatar
So it seems that my car is (not) tuned improperly.
Old May 3, 2010 | 02:59 AM
  #52
tephra's Avatar
nah - your MPG means:
a) big boost leak - bad drivability???
b) clogged cat - bad drivability???
c) dodgey fuel - slugish?
d) *02 sensor problem
* most likely...
yes evo's run rich from the factory, but unless your on a racetrack you should see those MPG's even with the factory tune!
Old May 3, 2010 | 03:27 AM
  #53
JED_POLAND's Avatar
* most likely...
a) n/a
b) n/a
c) n/a
d)? - but I had o2 sensor fault on E8 and it was taking 60 (sixty) l/100km at 150-180km/h. I checked it few times .
The car runs normal and is said to be "very fast" as for 333fHP only.
More over if any of above was the case would I be able to go down to 10-13l/100km?
Old May 3, 2010 | 03:47 AM
  #54
tephra's Avatar
whats E8?
a stock evo x from the factory should AVERAGE about 13L per 100km - thats highway/city driving...
what sort of driving do you do?
Old May 3, 2010 | 03:58 AM
  #55
JED_POLAND's Avatar
whats E8?
Mitsubishi Lancer Evolution Eight.
That is what people keep telling me.
WOT/brake/WOT/brake., etc.
Old May 3, 2010 | 05:24 AM
  #56
tephra's Avatar
WOT/brake/WOT/break is NOT normal driving... so of course your MPG will be ****house...
Old May 3, 2010 | 05:36 AM
  #57
JED_POLAND's Avatar
Well, depends on point of view...
Anyway - not pushing the car makes it 18l/100km. Period.
Old May 3, 2010 | 06:21 AM
  #58
tephra's Avatar
do me a favour...
sit on 100km/h, flat road - reset the trip computer and record what L/km you get... you should see between 10L/100km and 12L/100km
18L/100km is pretty terrible as well...
Old May 3, 2010 | 06:34 AM
  #59
JED_POLAND's Avatar
Will do in 5 weeks as I am 11000km away from my car (SIN).
Well, 100km/h is very eco speed, isn't it?
Old May 3, 2010 | 06:36 AM
  #60
tephra's Avatar
just a benchmark
