Sponsored by:
Sponsored by: CARiD
ebrake handle loose?
Old May 5, 2010 | 12:18 AM
zerocooll21's Avatar
I just noticed my ebrake handle assembly wiggles side to side when its down, does anyone else have this problem? I popped the top center console part off and looked in side, didn't see any bolts that hold it in place just one big rivet. I'm going to have to take the whole center console apart to get a better look but just wanted to know if anyone else had this issue. Thanks
Old May 5, 2010 | 01:13 AM
2SHIFTY's Avatar
Originally Posted by zerocooll21
I just noticed my ebrake handle wiggles side to side when its down, does anyone else have this problem? I popped the top center console part off and looked in side, didn't see any bolts that hold it in place just one big rivet. I'm going to have to take the whole center console apart to get a better look but just wanted to know if anyone else had this issue. Thanks
I second this motion..Same here
Old May 5, 2010 | 07:33 AM
Hmmm, I always use the ebrake and I can't believe I just noticed it. I got almost 5k miles now, I'm wondering if it just got loose over time.
Old May 5, 2010 | 09:35 AM
scorpeus401's Avatar
Nope, no wiggle on my e-brake. 18k miles on the car.
Old May 5, 2010 | 09:44 AM
TK-EvoX's Avatar
I havent notice the ebrake being able to wiggle but the chrome part on my ebrake actually came loose. There's a small screw on the bottom that came loose on me. Had to get it warrantied at the time. That small piece was $360+ had warranty not cover it.
Old May 5, 2010 | 12:46 PM
DarthEvoX's Avatar
This is very strange. Is it the entire assembly, or just the handle?
Old May 5, 2010 | 12:56 PM
Cory@AMStuning's Avatar
Customer dropped off a X yesterday and as I pulled it into the shop and yanked the ebrake the handle fell off.
Tightened the allen bolt on the underside of the handle and it's all good.
Cory
Old May 5, 2010 | 03:05 PM
Cory
Sorry I guess that could have been read either way. I'm not referring to the actual handle piece its self that comes in aluminum on the MR's. I'm talking about the entire assembly of the ebrake. When its all the way down I can grab it and shake the whole thing.
Old May 5, 2010 | 05:13 PM
JustNelson's Avatar
Cory
Hahaha how hard did you pull that
Old May 5, 2010 | 07:02 PM
Xtremist's Avatar
Depending on how many notches you pull the lever you could have stretched the ebrake cable which would allow slop. If you read the manual (not saying you haven't) it states you should never pull the lever more than 5 notches.
Old May 5, 2010 | 07:40 PM
So pulled it all apart and its definitely a rivet
Wiggle one way
Wiggle the other
I only got up three clicks. There is a nut that you can turn to adjust the tension. I tried that but it didn't solve the issue. When there is full tension you don't really notice it, its only when I have it down that you get the wiggle.
Old May 10, 2010 | 12:17 PM
Wow.
My bad. That's definitely way more than a simple allen in a handle.
Best of luck with it.
Cory
Old May 10, 2010 | 04:37 PM
LiQuIdCrAzN's Avatar
my ebrake is also suffering with this case... rather annoying and makes me afraid to put my hand on the handle when i drive.
Old May 11, 2010 | 06:26 AM
No worries, I should have been a little specific. I'll take it in once I get across the states, keep you guys posted.
Old May 11, 2010 | 09:02 AM
ohitisethan's Avatar
my hand break also has this problem but i thought it was just normal.
