Sponsored by:
Sponsored by: CARiD
Opinions for next mod
Old May 8, 2010 | 12:48 PM
jeangtd's Avatar
heres what I currentlly run on my 2008 gsr
aem intake
cobb downpipe
cobb hfc
magnaflow catback
cobb stage 2 aem 93 oct
cobb front and rear sway bars
exedy cerametalic clutch
I am slowly modding the car en enjoying each new part i put inthe car, one at a time. so wihich do you think my next mod should be to gain some more power. i am more than pleased with the handling with the new sway bars.
Old May 8, 2010 | 01:04 PM
Skyline559's Avatar
upper and lower inter cooler piping and maybe a tune.
Old May 8, 2010 | 01:08 PM
jeangtd's Avatar
no intercooler?
Old May 8, 2010 | 01:09 PM
Swedish Pride's Avatar
Well, it would seem you're currently knocking out the bolt-on mods for power and only have a few left to go. I would go for an intercooler/intercooler pipe setup. The upper pipe has shown to give some minor gains, but it isn't really breaking the bank to get it either. The intercooler will cost you a little bit more, but while it doesn't necessarily gain power for you, it will gain consistency in the power your engine can maintain as it gets hotter.
Old May 8, 2010 | 01:10 PM
Methodical4u's Avatar
I just added a grimmspeed 3 port and a Perrin recirc BOV and my boost is MUCH better at higher RPM's... that would be an idea, I already had a TBE, UICP, Drop in filter and was stage 2 AP.
Old May 8, 2010 | 03:28 PM
jeangtd's Avatar
so IC piping is next......thank's, thats waht i thougt so
Old May 8, 2010 | 09:10 PM
Ltdanish07's Avatar
dont waste your time with a LICP
Old May 9, 2010 | 06:02 AM
waltezee's Avatar
^ I guess you would recommend the SSQV so he can here it.
Your stock BOV will work fine for your needs at this time.
Old May 9, 2010 | 06:30 AM
evillancer06's Avatar
Veteran: Navy
meth
Old May 9, 2010 | 06:39 AM
rrkpitt15's Avatar
What about a BOV or WGA??
Old May 9, 2010 | 11:40 AM
jeangtd's Avatar
what do you suggest?
Old May 9, 2010 | 02:35 PM
ugakirk's Avatar
LICP doesn't really give you any gains, atleast on the stock turbo. I went ahead and changed mine tho.
I would do intercooler pipes and an intercooler if you have the money. Maybe get give Mellon a call and get them to get you a tune via e-mail for your AP. That would make a big difference over the AP map.
Old May 9, 2010 | 03:38 PM
wiretap's Avatar
Upper Intercooler Piping + Intercooler
With a tune that will give you some good gains.. plus on hot days an upgraded intercooler will definitely help versus the stock intercooler. Someone on here had a graph of the intake vs. intake plenum air temp deltas and it was like night and day after the swap.
Old May 9, 2010 | 03:50 PM
danko's Avatar
I'm vote #4 or so for the UICP and Intercooler without a doubt. I think that's a good next step for you.
Old May 9, 2010 | 03:55 PM
hotdog's Avatar
The stock LICP is a nice piece.
I only changed mine for methanol jet install, simpler to weld a bung in in my mind.
