Sponsored by:
Sponsored by: CARiD
Opinions for next mod
Old May 9, 2010 | 06:12 PM
CatalystGod's Avatar
You can go to any one of these and see improvements:
1) UICP
2) IC
3) 3 port boost solenoid (This will need (4))
4) Custom Tune.
Old May 9, 2010 | 06:57 PM
jeangtd's Avatar
I am thinking meth because of the crappy fuel we have over here, if i dont get a tune for meth will i still see gains?
also, for the piping upgrade, only the upper piping is necessary?
Old May 10, 2010 | 12:32 PM
Ltdanish07's Avatar
Originally Posted by waltezee
^ I guess you would recommend the SSQV so he can here it.
Your stock BOV will work fine for your needs at this time.
What are you getting at? What does any of this have to do with a SSQV?
Old May 10, 2010 | 02:56 PM
hotdog's Avatar
You'll basically be running rich with no tune on methanol. I suppose cooling the intake air might gain some, but I think it'd mostly be a wash.
On the X, only the UICP is really useful, yeah. The LICP is more of a show piece. But, if you're doing methanol, IMHO, the cleaner way is to get a bung welded in your LICP for the nozzle.
Old May 10, 2010 | 03:07 PM
utggevox's Avatar
FMIC, UICP, and E85 if available and all supporting mods. Youll absolutely love it with the fast spool of stock turbo and all the hp tq. Thats if you wanna go that route.
Old May 10, 2010 | 05:39 PM
jeangtd's Avatar
heres the thing, apart form crappy fuel, 89oct i guess is what we get here, because it does not even say in the pump the octane. but i am at 8500ft amd running a 93 oct cobb map with no knock. but when i get to sea level i am not going to be able to use 93 oct so i fugured, run meth with no tune (i feel thae failsafes arent enough for me) and run 93 oct at sea level.
Old May 10, 2010 | 06:05 PM
R18eclipse's Avatar
heres what I currentlly run on my 2008 gsr
aem intake
cobb downpipe
cobb hfc
magnaflow catback
cobb stage 2 aem 93 oct
cobb front and rear sway bars
exedy cerametalic clutch
I am slowly modding the car en enjoying each new part i put inthe car, one at a time. so wihich do you think my next mod should be to gain some more power. i am more than pleased with the handling with the new sway bars.
3 Port Boost solenoid and a custom tune would be next for me...
I am not a real big fan of a staged off the shelf tune.
Old May 10, 2010 | 06:46 PM
jeangtd's Avatar
Ok with my setup, would the 3-port be plug and play or do a need a tune? if you are not biased which one do you recomend
Old May 10, 2010 | 07:17 PM
waltezee's Avatar
Your going to need to get a tune to get the boost levels set correctly. I've heard a lot of good things about grimspeed.
Old May 10, 2010 | 07:27 PM
jeangtd's Avatar
then no go, we dont even have a 4x4 dyno here
Old May 10, 2010 | 09:29 PM
R18eclipse's Avatar
+1 on grimmspeed, i have used several for STI and EVO. They work great... you will need atleast someone to do a good road tune to set WG cycles on your ROM...
Old May 10, 2010 | 09:32 PM
Aaron20's Avatar
tune and IC
Old May 10, 2010 | 09:35 PM
jeangtd's Avatar
already talked to the guy that does road tuning for me and told me it was a hassle, that i should do this last
Old May 10, 2010 | 10:32 PM
R18eclipse's Avatar
If he knows what he is doing and understands tuning an evo....It should be pretty basic to him.
Too bad you dont live in California. I'd do it for you..
R
Old May 10, 2010 | 10:49 PM
jeangtd's Avatar
R
too bad I dont live in the US jajajaj
rognasty
Jun 22, 2016 06:02 PM
EVOSWAG
For Sale - Part Outs
Jul 4, 2014 11:08 PM
Hydroyo
Jun 3, 2014 03:06 PM
alsong2002
Jan 24, 2014 08:01 AM
adean12
Jun 6, 2011 03:07 PM
