Sponsored by:
Sponsored by: CARiD
Is there any update on a hid fix for GSR.
Old May 31, 2010 | 07:07 AM
zerocooll21's Avatar
I know the dealer can plug the car in and see the command to shut it off but for some reason they couldn't shut it off. I saw a couple people post this trying to do the same thing. Maybe the dealer they went to just didn't know what to do..
Old May 31, 2010 | 07:24 AM
bong09's Avatar
Well my car is in the dealer now. They said they will call me later today.
Old May 31, 2010 | 07:28 AM
Nice, let us know!
Old May 31, 2010 | 10:34 AM
HudsonFalcon's Avatar
I've heard that the dealer can find the command to change the car from non-SSS to SSS but cannot change it since it's locked for some reason.
Old May 31, 2010 | 07:00 PM
bong09's Avatar
Well I got my car back, they could not change it. We need some one to be able to hack that system or jailbreak it. I am disappointed but just move on until someone hacks it. Sorry guys for the disappointment.
Old May 31, 2010 | 07:15 PM
I figured as much. Pretty stupid that they an see the command yet do nothing about it.
Old May 31, 2010 | 07:32 PM
wiretap's Avatar
Yup. I took my car in and they hooked it up to the computer. They can get all the way to the setting to turn off DRL's, but it locks them out from doing so.
Old May 31, 2010 | 07:33 PM
^ ha there we go, wiretap was the guy I saw who already went through this
Old May 31, 2010 | 08:41 PM
bong09's Avatar
They should not put it in there if it can not be changed. I just hope there is a person that is able to break through the coding. Well there is hoping.
Old May 31, 2010 | 09:41 PM
bong09's Avatar
Originally Posted by XBoost
I'm receiving my first batch of (8) DRL Bypass Relay Harnesses for 08-10 Lancers and Evo X's that I've been working on mass marketing. This harness will retain normal function of the HID's (not turn them on when switched to parking lights like the solution above). These will hopefully be for sale on evolutionm.net. Cost is going to be about $35 shipped for any member. I should have these available about the second week of June...please anyone let me know if they have any interest. Thanks!
You think you have a set for the mr headlights? If so that would be great.
Old Jun 1, 2010 | 01:23 PM
I don't mind having the DRL's in fact there's a recent thread where a member put LED's into his daytime running lights and they looked great. My issue is with the flickering, if someone could come up with a harness or fix for the flicker then that'd be sweet.
The dealer being able to find the DRL command and not being able to change it is pretty weak but I'm sure they'd love to sell you a new ETACS!
Old Jun 1, 2010 | 02:05 PM
bong09's Avatar
I found a DRL module that will work to get the DRLS on the right bulb and I just need a way to disable the stock DRLs. I want to keep the DRLS working, it is the flicker that is bugging me. I do not want to leave the headlight always on.
Old Jun 1, 2010 | 02:35 PM
kdiggz's Avatar
wow i had no idea about this issue. glad i read this
Old Jun 2, 2010 | 12:51 PM
XBoost's Avatar
If your MR is Non-HID then yes...if you have a factory HID system all you have to do to disable the DRL's is pull the "DRL" fuse in the fuse box. Wish it was this easy for us non HID guys but this is why I came out with this rather low cost solution.
EDIT: Just realized your swapping MR headlights into your GSR. Unfortunately, my bypass will only be able to bypass GSR (9006) head lamps. Sorry for the confusion.
Old Jun 3, 2010 | 01:47 PM
bong09's Avatar
Thank you anyways for the help, mine is a non sss gsr. I am going to try the option 3 bypass.
