Sponsored by:
Sponsored by: CARiD
AEM boost gauge, is this normal?
Old Jan 2, 2026 | 12:31 PM
MAKuzian's Avatar
If you see vacuum only and no boost reading on the gauge, sounds like its connected in the wrong place. I'm not sure what would have vacuum and not see boost though, unless there is an issue with your boost...
Old Feb 16, 2026 | 06:04 PM
RallySport9's Avatar
Originally Posted by Alberto0216
Correct but my other question is so I read o when it’s off when it’s idle I read anywhere from 20ish and when I get on it reads lower numbers up to 0 is this normal?
its normal unless you're in gear and apply engine load then you should start to see real positive boost pressure. Just revving in neutral the highest your boost will go is 0 or just barely above. Otherwise it should be 0-20 inch/hg.
foxbear2277
Jun 5, 2012 03:14 PM
devildevil
Oct 6, 2010 11:50 AM
MICLOIV
Jun 6, 2010 08:00 PM
Maximum404
Mar 7, 2009 01:22 PM
JBud72
Dec 20, 2008 12:34 PM
