Sponsored by:
Sponsored by: CARiD
how to tell...?
Old Aug 18, 2010 | 08:34 PM
lancerarmstrong's Avatar
how to tell...?
I've searched the forums for a while and didn't see anything on here in particular reguarding my question. How does one test for exhaust leaks? I just got done putting on a cat-back exhaust and i think the only part i am most worried about is the part that meets up at the cat, since there is that heat shield you have to cut. what i did is i cut it every half inch or so in slits, bent them back so it looks kind of like a cog gear, put the exhaust in w/new gasket, and bent them back over. it doesn't SOUND like i have a leak, but then again this is my first catback i've installed ever.
Old Aug 18, 2010 | 09:27 PM
rmondoh's Avatar
You know, I don't really know how to do it either but if I had to guess, I'd probably do it the same way you'd check for a puncture on a tire: Soapy water. Put some in a spray bottle and then spray it at the cat - mid pipe connection and look for bubbles.
That's my guess unless someone has a better idea.
Old Aug 18, 2010 | 10:52 PM
thats a good idea but would it just bubble from heat alone or no?
Old Aug 19, 2010 | 06:47 AM
ugakirk's Avatar
Not if the car had been sitting for a while and you started it up.
Old Aug 19, 2010 | 06:55 AM
dek0026's Avatar
if you had a leak from the cat, you'd hear and smell it but the above method couldn't hurt if you're really worried about it.
Old Aug 19, 2010 | 06:56 AM
journeymansteve's Avatar
Look for the carbon soot. You might see it on pipes or on body/chassis parts near the exhaust.
Old Aug 19, 2010 | 07:04 AM
tsitalon1's Avatar
There's an app for that!
Sorry...had to.
Just smell and feel around. It's also ok to have someone block the exhaust pipes for a few moments at atime while you check certain sections.
Old Aug 19, 2010 | 01:05 PM
LMAO.
Old Aug 19, 2010 | 01:31 PM
SOG RA's Avatar
Best way to check for an exhaust leak is with a stethascope type tool. A lot of shops use it, it just has a different tip on the end. You can go to any exhaust shop or muffler place and they would do it for free.
Old Aug 19, 2010 | 06:13 PM
turbotony972's Avatar
The most common method is simple... start your car then put your hand around the area that you think is leaking. If you feel air than clearly you have a exhaust leak. Also sometimes the car will backfire under decel with a exhaust leak.
