Sponsored by:
Sponsored by: CARiD
Test pipe with stock exhaust system pros and cons?
Old Aug 21, 2010 | 10:45 AM
monkeyfish76's Avatar
Without a tune u will run super rich. I ran a test pipe with stock exhaust for a few months and didnt notice any huge power gains. Installed a full catback and had it dyno tuned at modified by kc. 335 awhp & 323tq with only mods being catback and test pipe.
Old Aug 21, 2010 | 10:52 AM
marc-111's Avatar
you would just haina few hp if you runa test pipe with a stock exhaust.....it's better to change to full exhaust to notice the hp increase
Old Aug 21, 2010 | 08:28 PM
edogg23's Avatar
Isn't the largest restriction in the stock exhaust the cat?
Old Aug 22, 2010 | 04:26 AM
Noize's Avatar
EvoM Administrator
Yes, it is by far the biggest restriction. There is a ton of misinformation in this thread.
Evo IX same tuner pre and post, I had a friend make 12whp with just the addition of an Ultimate Racing test pipe. Lots cooler EGTs as well.
Same thing with an Evo X, put a turbo-back on it and tune both ways with a HFC, you'll make 12-15whp more with a test pipe. The restriction is the worst at high rpm.
Old Aug 22, 2010 | 04:10 PM
Maverickvf84's Avatar
Bro get a TBE!!!Just save up and get the whole thing!Last year I got the UR Cat-back exhaust then just 2days ago I got the last UR resonated testpipe!along with my AMS DP the this TBE is gr8!!!Large power gain...but I couldnt dyno/tune becuz this other guy was abotu 2do a E85 tune and i wasnt about to sit there all afternoon...ill go back another day to find out my numbers now but I can surely feel the gains + the fluttering i was gettin from my wastegate becuz of my 3-port boost solenoid went away!
Save up and do it at once...a testpipe + a stock exhaust that was proven 2b super restrictive seems like a waste of time 2me...but thas just me...
Old Aug 23, 2010 | 04:25 PM
YShen15118's Avatar
Drew,
check out the Magnaflow catback for the Evo X. It looks almost identical to stock. And it's cheap too.
Old Jul 1, 2012 | 06:04 PM
freethriftyz's Avatar
I did this, it made a nasty sound at WOT sometimes tho. Super stealth, that + intake, uicp, 3 port got me 402wtq
Old Jul 1, 2012 | 07:12 PM
X Evolution X's Avatar
Originally Posted by MaxR
you won't need a tune, if your ECU is stock
you only need a tune if you flash'd first, then add the test pipe
Nor sure this is correct, chances are if you go with a down pipe and best pipe, you will experience some over boosting and creating knock.
I personally wouldn't want that for my car, so I went with catback for now until I am good and ready for a tune.
Old Jul 2, 2012 | 06:59 AM
b3n's Avatar
b3n
I ran a TP and O2 DP with the rest of the exhaust being stock for a stealthy look...with Cobb's stage 2 tune, the gains were good. Prepare yourself for the smell though...
Old Jul 2, 2012 | 07:45 AM
Alpha X's Avatar
Originally Posted by derekste
con: you will be an environment polluting a-hole for the spectacular gain of .5whp.
go buy a good high flow cat and avoid being a dick.
Tell us how you really feel about those that run test pipes
Old Jul 2, 2012 | 07:49 AM
CaptainAsia's Avatar
Can you run a stage 2 on the AP with just a hfc or tp on a stock exhaust? I went to a shop and they said it would create a lot of back pressure or something like that aka not good...
Frank Castle`
Apr 3, 2017 07:45 PM
richiivu
Evo X Dyno Results
Mar 14, 2016 10:18 AM
LancerGSRx
Mar 21, 2014 10:57 AM
BadAssEvo
Nov 2, 2013 05:40 PM
4080wrx
Aug 20, 2009 02:41 PM
