Sponsored by:
Sponsored by: CARiD
Code p0017
Old Nov 10, 2010 | 04:49 PM
07outty's Avatar
Code p0017
got SES light scanned and got code P0017.
crank/camshaft position sensor.
any one ever get that code ?
have not done anything to the car lately or done any "hard" driving.
Old Nov 10, 2010 | 05:10 PM
WarmMilk's Avatar
i don't remember exactly the code i got, but it was the camshaft position sensor. the dealer ran a check on it and the sensor was fine. the oil control valve that sends oil to the solenoid was faulty. my SES light went out by itself the next day before I got to the dealer, I didn't clear it. so get it checked out even if the ses light goes out (or doesn't come back if you cleared it)
I'm still waiting for the part to come in, the dealer didn't have it in stock.
i started a thread on it, but nobody had any useless info, just telling me to stop b*tching about my ses light coming on at such low miles...
Old Jan 9, 2012 | 03:32 PM
robearralliart's Avatar
2010 RA Sportback
I got a P0017 code when the SES light went on about 2 weeks ago.
I have Chain Stretch issue at 9,000 miles, which the dealership fixed.
I now have 17,000 miles on the car.
It started stumbling in idle, and rpm, and the tranny was shifting really high RPM, then dropping really low.
Dealership has replaced the following:
Oil Control Valve
Timing Chain
Re-downloaded ECM & TCM program
Still throws a code right at start up.
They have had it almost 2 weeks. The dealership cannot diagnose the problem, and have no answer for me as of today.
It is still under warranty, that is why I took it to the dealer.
No upgrades, ever, not even a k&n.
Can any of the EVO & RA gurus here help me?
Old Jan 9, 2012 | 07:49 PM
07outty's Avatar
mine ended up being just the oil control solenoid.
replaced under warranty.....car has run great ever since the repair.
Old Jan 10, 2012 | 12:52 AM
GreenOctane's Avatar
hope its nothing serius
Old Jan 10, 2012 | 09:33 AM
Get Rad's Avatar
Exhaust cam sensor. I pulled this one a few months ago.
Old Jan 10, 2012 | 09:45 AM
76stingracer's Avatar
Have they checked for chain stretch again?
Old Jan 10, 2012 | 09:56 AM
Get Rad's Avatar
Could the Chain stretch be the reason why a exhaust cam sensor code is being displayed?
Old Jan 10, 2012 | 03:34 PM
Update:
Got it back today.
Cause: Found Code P0017
Engine Oil Control Valve (Exhaust) - Replace
Sensor - Camshaft Position
Valve, Oil Feeder Control
Per TSB 11/13/2008 Tech Reprogrammed ECM. After Re-prrgram & Test drove, code P0017 reset. Replaced Exhaust Side Cam Sensor. After cam sensor, code reset.Inspected timing chain, found good. Replaced Exhaust Oil Control Valve & Re-programmed, Drove 85 miles, No Code found.
I hope that I am done with this issue. I am scared to do anything to the car, as I would have to strip it down everytime I take it to the dealer.
But, I hope these few posts anybody else having the same issue.
Old Feb 25, 2012 | 02:00 PM
ptakats's Avatar
i got the code p0012 over the weekend and took it in to the dealer (still under warrantee) and they said the timing chain was loose from over revving. To quote "the timing chain is sensitive on the evo and should not be revved" and so because nothing was TECHNICALLY broken, i have to pay for the diagnostic process.... stealerships.......
chris4b11t
Mar 11, 2017 07:51 AM
bhaikalis
Jun 5, 2016 08:49 AM
302Squill
Mid-Atlantic Region
Aug 21, 2015 09:22 PM
evokid4life
Mar 25, 2013 10:13 PM
04Evo851374
Dec 17, 2012 12:14 PM
