Sponsored by:
Sponsored by: CARiD
Gauges...Double Sided Tape Sucks
Old Dec 13, 2010 | 12:42 PM
stokEd's Avatar
Originally Posted by ToddMcF2002
As an aside, I've decided AEM makes cheap *** looking analog gauges. The Defi makes it look like it came out of a bubble gum machine To add insult to injury it gets *brighter* when you turn on the headlights and the Defi dims. WTF Oh and it has a hot spot on the back light right at top dead center.
There was a guy that was making a simple power inverter to solve that quirk a while back. Unfortunately, that was the last I heard of it. I remember him saying that AEM had given him instructions on how to make it. If it bothers you enough you could give them a call and see if they can help you out.
Old Dec 13, 2010 | 12:47 PM
stokEd's Avatar
Here is how I got around that...
But yeah, the Defi gauges do look better than the AEM IMO.
Old Dec 13, 2010 | 12:59 PM
sstevojr's Avatar
Prosport, they look **** ;^P
Old Dec 13, 2010 | 01:01 PM
ToddMcF2002's Avatar
LOL I suppose the absense of a Defi makes them look better. Do you have backlight hotspots too? Mounting the Perrin off center, now THAT is function over form!
Old Dec 13, 2010 | 01:02 PM
Yeah but I like to wire my gauges once, not once per season
Old Dec 13, 2010 | 01:18 PM
stokEd's Avatar
Yeah, around 10psi on the boost gauge.
Thanks. I'm happy with it, it looks good and only covers 0-15mph on the speedo and none of the tach. I do like where you have yours mounted though, if I ever do things over I might try mounting mine like that.
Old Dec 13, 2010 | 01:29 PM
The binder clip idea I stole from someone else on the board, forget who. I almost got the Perrin, and likely would have offset them as you did. Really the X has few actual good options.
Old Dec 13, 2010 | 02:25 PM
Touge Factory's Avatar
We use 3M molding tape - professional strength (we get it in 25 yard rolls)
Few body shops use this to attach fender flares / body molding / emblems etc...
I have my defi gauges for almost 2 years in the exact same spot - never moves. even when the temps get to -25 degrees.
good cleaning of the surface helps - especially if you use armor all or something similar.
Stuff works so well that we received calls from customers to see if we "super-glued" certain parts onto their cars. A little bit of heat takes it right off.
Old Dec 13, 2010 | 04:09 PM
LaXGSR's Avatar
I never had problems with the "3m dual lock" tape. It's a much strong alternative to velcro, and seemed to work well for me...
Old Dec 13, 2010 | 06:00 PM
stokEd's Avatar
Thanks for the review! I see this stuff at the autoparts store every time I'm there and have always been hesitant to pick some fearing it wasn't that great. I have a few things I need to tape down that my loctite tape dropped as soon as the weather got cold.
Old Dec 14, 2010 | 12:04 PM
tack's Avatar
Both of these gauge set ups look great! I am in the market for gauges, you definitely prefer the Defi over the AEM? How long did it take to install the gauges?
Looks great guys!
Old Dec 14, 2010 | 12:16 PM
AWDTerror's Avatar
just like a few others have mentioned 3m molding tape works wonders...as long as you clean or prep the surface. I use 90% rubbing alcohol and a paper towel.
Old Dec 14, 2010 | 02:56 PM
Wrex1977's Avatar
I've had bad luck with tape in the heat. It will get all gooy and then stop sticking. I will have to try the 3M and see if it's any better.
Old Dec 14, 2010 | 04:42 PM
stokEd's Avatar
Looks great guys!
The Defi gauges look better than the AEM gauges, but both do the same thing. Defi doesn't make widebands so I went with AEM for both gauges because I prefer the uniform look.
And install will take up some time, especially if you're **** about routing everything nicely and soldiering everything together.
MrDeltaKilo
May 19, 2014 12:28 AM
youngcow
Jun 25, 2013 05:39 AM
evilempire76
Aug 12, 2007 10:08 PM
avo3vom
Aug 12, 2007 08:56 PM
acidandroid
Dec 18, 2005 10:33 PM
