Monitor AFR on Accessport without gauge?
I've been researching this for days and hoping to find help.
On the Accessport there is an option to monitor WB AF data. I have a bung waiting on my down pipe for a WB but I don't want the physical gauge cluttering my dash. (Say what you want about that, it's beside the point).
Just wondering if I can wire the actual gauge using that yellow wire trick, or if it has to be a wire coming off of the gauge.
I've looked into this as well and I think what you need other than another O2 on your exhaust is this unit:
http://www.innovatemotorsports.com/products/lc1.php
If Cobb finds an easier solution then please share it.
Other than going through the installation instructions that are located at the bottom of the link I gave you (which I have not read) then I wouldn't be able to answer your question.
I've just looked into this issue myself and from what I've read and been told this is really the easiest way to go with this setup. I have an AP V3 as well and I don't want extra gauges. I would rather just use the AP for multiple gauges and leave it at that.
Did some tinkering around today at the shop and I did finally happen to find a diagram of the connection between the stock rear O2 and the ECM.
(Excuse the filter. Made the text stand out a bit better)
I suppose I'll order that LC-2 and make an attempt at wiring it how I think and see how it turns out. If it's programmable, it doesn't much matter what COBB's formula is because one would just change the LC-2 output to match it. Hopefully in the meantime I hear back from COBB or somebody here chimes in with a better (more confident) answer than I'm workin with, heh.
Methodical4u
Sep 9, 2016 08:41 AM
AWDTerror
Apr 11, 2013 09:59 AM
