Sponsored by:
Sponsored by: CARiD
Is it ok to...
Old Jan 24, 2011 | 10:24 PM
phishy's Avatar
Is it ok to...
Spray down your engine bay? I'm asking cause my radiator cracked and spewed coolant all over the place. Head, pipes, lines, etc...
What should I cover up? All connectors? Oh and I'm not talking like a spray down as if I were watering plants outside, I mean a quick power spray @ a say coin op car wash and hose down the pay for about 15-30 secs?
Thanks
Old Jan 25, 2011 | 12:45 AM
Fittest's Avatar
Most people would advise you to cover up the battery and distributor. Other than that, fair game.
Old Jan 25, 2011 | 06:00 AM
Kracka's Avatar
X's have neither in the engine bay
Be gentle on the ECU and air filter (if open-element) though.
Old Jan 25, 2011 | 06:24 AM
Crester's Avatar
I would just cover up anything electric and then clean the engine bay. On a previous car some newb at the dealership decided to clean my engine bay. The idiot held the spray/steam wand right over the spark plugs and caused water to get inside. As a result... when I came to pick up the car the engine way shaking so violently I thought it was going to rip itself out of the car. The dealership had to replace all the spark plug wiring.
Old Jan 25, 2011 | 08:14 AM
ugakirk's Avatar
That's what I was thinking.
I wouldn't "flood" the engine bay with water or take a pressure washer and hit the electronics.
A little bit shouldn't really hurt it.
Old Jan 25, 2011 | 08:25 AM
FALCO's Avatar
Do not spray down a hot motor with very cold water.
Old Jan 25, 2011 | 08:46 AM
libz's Avatar
im not a big fan or water in the engine bay lol i usually take my sweet *** time with a rag and soap water and wipe it off...sucks alot but maybe if someone took pictures of their engine bay ready to be sprayed down?
Old Jan 25, 2011 | 09:37 AM
apexisilver8gsr's Avatar
yeah thats pretty much all you have to do
Old Jan 27, 2011 | 12:02 PM
TTsumibishi's Avatar
Make sure the engine is cool to the touch. Otherwise, have at it. This is how I've always cleaned my engine bays. Spray a little P21S TAW (total auto wash) and use a detailing brush to agitate the dirt and hose it off, it'll look like new.
Dry most of the plastic parts, then use some 303 Aerospace protectant on all the black bits. It'll REALLY look like new, or better.
I'd cover up where the battery terminal is and the fuse box just in case, however, you should be fine. Happy detailing!
Old Jan 27, 2011 | 10:51 PM
Beastmobile's Avatar
Is it a good idea to cover the alternator too? I've always done this but I'm not sure why. I think someone told me this long ago
Old Feb 9, 2011 | 01:10 PM
TJ4EVOTURBO's Avatar
And make sure you watch out for the police cause you don't want any kind of fine
Old Feb 9, 2011 | 01:32 PM
Wrex1977's Avatar
Also leave your engine running. If you shut it off and get water is a bad spot it might not start back up for awhile.
Usually you would use a lite cleaner and let it sit for a couple of minutes and then run water from your garden hose over the engine. This would clean most if not all of the junk off.
Old Feb 9, 2011 | 01:52 PM
eusgen's Avatar
^ This has me baffled
Old Feb 10, 2011 | 02:24 PM
Crester's Avatar
Some places it's illegal to wash off chemicals and have them go into the sewer. So if somebody sees a bunch of sudzy water going from your driveway and into a catchbasin you could be in trouble based on where you are.
Old Feb 12, 2011 | 07:43 PM
bobby0283's Avatar
Use some watered down Simple Green, that stuff gets the grime off of anything!
