Sponsored by:
Sponsored by: CARiD
AMS (GM) 3 port solenoid wiring?
Old Mar 6, 2011 | 09:30 PM
michiganevox's Avatar
I know this is a novice question but bare with me I just want to make sure I get it installed properly. There are two wire to the OEM and aftermarket 3 port solenoids. Does it mater which wire goes to each lead of the the 3 port solenoid? I purchased the AMS solenoid kit. My title may be wrong. This may not be the well referred to GM solenoid but it does have an automotive OEM part number on it. Anyway, I also purchased a connector so I don't need to cut into the OEM harness. Before I insert the terminals into the connector I want to make sure polarity doesn't matter.
Old Mar 7, 2011 | 07:07 AM
Magnumpsi's Avatar
Originally Posted by michiganevox
I know this is a novice question but bare with me I just want to make sure I get it installed properly. There are two wire to the OEM and aftermarket 3 port solenoids. Does it mater which wire goes to each lead of the the 3 port solenoid? I purchased a kit with the GM solenoid and I also purchased a connector so I don't nee to cut into the OEM harness. Before I insert the terminals into the connector I want to make sure polarity doesn't matter.
You are correct polarity does not matter.
Mitch
Old Mar 7, 2011 | 10:07 AM
evokerfes's Avatar
AMS carries the GM 3port? I can't find it on their website, can anybody give me a link?
Old Apr 21, 2011 | 09:47 PM
kikeixmr1982's Avatar
just look for AMSPERFORMANCE.COM
Old Apr 22, 2011 | 06:08 AM
AMS three port solenoid
My title at the top of this thread is probably wrong. This may not be the well referred to GM solenoid but it does have an automotive OEM part number on it. Anyway, I highly recommend the AMS three port solenoid. I was using a manual boost controller and experiencing large boost spikes. After installing the AMS boost control solenoid and tinkering with the map to get it dialed in with the great people over at AMS I have much better control of the boost.
TurboTravis
AEM EMS
Sep 2, 2010 01:29 PM
rolly1818
May 8, 2010 03:14 AM
Clipse3GT
22
Jan 11, 2010 09:47 PM
HybridKOOP
25
Aug 17, 2009 11:58 AM
Danieln
Jul 3, 2009 10:49 AM
