Battery question
Subscribe
Mar 8, 2011 | 01:15 AM
Well I'm gettin ready to take my 1,721 mile evo out of hibernation. Only thing is she didn't do anything when I wanted to start her. Had to use the emergency key to even get in. It started with a jump but when I shut her off at the gas station 5 miles away I needed a jump.
My question is do I risk dropping it off at a dealer for multiple days just to get charged for a new battery And a bunch of mystery miles or just buy a battery from walmart? I don't really trust letting anyone being around her. I waited 45 minutes to get it inspected when she only had 590 miles on her. Got her back with 15 extra miles and one happy mechanic :/
Reply 0
Mar 8, 2011 | 01:43 AM
Or get another battery and connect them, you now have double crank power.
Reply 0
Mar 8, 2011 | 09:21 AM
The car didn't do anything because you need to disconnect the battery if your car will be in storage for a while. And I doubt that your car would be at the dealership for a few days just for a new battery. Call ahead and make sure they have it at the shop if you're going to go that route. Gooood luck.
Reply 0
Mar 8, 2011 | 09:25 AM
If the battery won't hold a charge after sitting and getting drained (never store your car with the battery left in it) take it in and try for a warranty replacement.
Reply 0
Mar 8, 2011 | 09:26 AM
Your car is brand new just change the battery and then it will be fine
Reply 0
Mar 8, 2011 | 10:08 AM
i'm not sure if my evo is set up the same way because i haven't checked, but in my '09 lancer GTS when i had it, there was a jumper inside the fusebox underneath the hood that you're supposed to pull when storing your vehicle. it disconnects the main battery line from all the components that may cause parasitic battery drain (like the alarm, monitoring hardware, or anything else you might have). try to look for that and use it next time
Reply 0
Mar 8, 2011 | 11:06 AM
Yea for a new red top battery like the OE you are going to be looking at atleast $150.
Reply 0
Mar 9, 2011 | 12:52 AM
Well lesson learned
Reply 0
Mar 9, 2011 | 10:30 PM
Reply 0
Mar 9, 2011 | 10:35 PM
just save ur self time and trouble by going to advanced auto and gettin a new battery.....
Reply 0
Mar 10, 2011 | 05:10 AM
Mitsubishi will replace the battery for free with an optima red top if they get their test to fail. I had all sorts of issues with cold starting, and they ended up replacing the battery at no charge.
Reply 0
Mar 10, 2011 | 05:33 AM
Just remove the battery from the car and take it to a battery shop. Most battery shops like Batteries Plus, will charge your car battery for free. There's no need to take your car to the dealership or mechanic for just a simple battery issue.
Reply 0
Subscribe
