Sponsored by:
Sponsored by: CARiD
Fans kept running
Old Apr 18, 2011 | 05:06 PM
ravenjam's Avatar
Fans kept running
Today I got to work, switched off and got out of my car. I then noticed that the fans were still going. I got back in and made sure the car was really switched off, it was. While i stood over my engine a little freaked out, it then turned off. Is this normal for a Evo X GSR?
Old Apr 18, 2011 | 05:15 PM
SilverJesterGSX's Avatar
I believe I read in the manual that the fans can stay running for up to 3 mins after you shut the car off.
tico915007's Avatar
Normal I try to keep my car on when I get home from sprinted driving to let it cool down on its own. If car is too hot fans will stay on not for long if you turn it off
Old Apr 18, 2011 | 05:24 PM
Segfault's Avatar
yes, it's normal.
Old Apr 18, 2011 | 05:29 PM
ravenjam's Avatar
Originally Posted by Segfault
yes, it's normal.
Thanks, thats good to know. I had the car for 3 months now and have driven spiritedly and its never happened, go figure
Old Apr 18, 2011 | 05:38 PM
total0wnage's Avatar
In the ralliarts we experience the same thing after spirited driving- its a stock turbo timer which leaves our car on for another minute after turning off the engine
Old Apr 18, 2011 | 05:51 PM
iceman1680's Avatar
Yeah there are two criteria that are checked by the ECU at ignition shutoff - coolant temp and A/C switch on or off - to determine whether the fans will stay on. It's in the manual.
Old Apr 19, 2011 | 08:02 PM
terror DAVID's Avatar
if the maf sensor reaches a certain degree then it will triger the fans. only when it gets to that degree
Old Apr 19, 2011 | 08:54 PM
lancerarmstrong's Avatar
definitely normal, in fact i was reading that in my manual a few months ago while learning how to program the FAST keyfob. if your engine is running hot at the time of shutting it off the fans can keep running for a while.
Old Apr 20, 2011 | 09:55 AM
Crester's Avatar
I doesn't happen to me much... but it did happen to before. Just like you... the first time it happened I kinda was freaked out. But it just went off after.
TURBO_S2K
Jun 3, 2025 12:10 AM
Spythere
Jul 5, 2016 03:09 AM
utggevox
Jun 10, 2012 04:30 PM
98autogstspyder
45
May 16, 2009 12:23 AM
Davo
May 26, 2008 07:06 AM
