Evo X GSR - R&T June 2011
to get more power out of the car, they all come pretty modest from the factory
@modvp
they put a baseline flash on before they adjusted for the last two pulls (so i didnt get a 'from the factory' pull) and i was at 269/274 if i can remember correct, got the sheets home with the car, had to come back to afghanistan
@modvp
@modvp
@modvp
not sure but if anyone has gotten any work done by Atlantic Motorsports in MD and knows let me know. I also had my boost turned up and with the boost gauge it spiked at 27 lbs. and i think i hold about 24 or 25 lbs.
also i never saw what the 'stock' pull was, the first pull was after they loaded a baseline flash and went from there.
yes they were really knowledgable and after going the IAG (Subie) then going there and seeing 5 Evos in their bay I knew I found a good place. I appreciated their honesty and the 'well we dont want to tell you what to spend you money on but you dont need that' factor was a deciding factor *when i inquired about a BOV*. they took time to learn my name after two visits and the crew were very professional, along with updates when things dont go to their plan, i was looked for and given a dyno graph after each pull. they arent paying me either, check out their facbook page i posted a comment about the quality of their work. can say enough good things but as an example met a guy with a tc with 360 whp that drives from VA to get his car worked on there, and i drive from east baltimore to get there. brother in law *2011 mazdaspeed3 and good friend *wants a STI will also be switching to their shop. sorry everyone else just good shops arent as common as you might think in some states
SN: they also have a sick lookin WW 10 there
@modvp
@modvp
Can't wait to get tuned though.
Lol, just did some pulls and at full boost the AFR was 10.2...that's with TP and catback. I wonder how the 2011s are putting down those numbers when the AFR is still pig rich? I imagine there are other variables that determine HP and Tq that I'm not aware of...
well the guy who did my tune adjusted my AFR so its a bit more balanced when in full boost (better fuel economy too), the boost was also raised i spike at 27psi and hold about 25. im aware of the same hp tq variables you are gasoline and oxygen... unless i been told things wrong
I was making 26 psi on stock flash, I also got a pm from another member on here with a 2011 that said he spikes to 26 on the stock tune sometimes.
while the 2011 makes more power stock (I dyno'd 282 bone stock on a different dyno than the link below, but also a dynojet), a tune is still very very generous (picked up 60 whp at 5500 rpm)
https://www.evolutionm.net/forums/ev...d-english.html
Just casually reread the article, something caught me by surprise - while they praise the handling of the X, they say it's not as precise as the Nissans? And this is the regular Nissan 370Z, not the Nismo - with more chassis stiffening.. Also the 370Z's lsd is just a regular old viscous type, nothing special at all
