i need so input on 2 different routes i want to take with my 2011 gsr
what i currentl have done: ams intake, turbo xs tbe, grimmspeed ebcs
im either goign to buy ams front mount kit, injectors, cams, fuel pump,vavle springs (if i dont need injector let me know)
or
ams front mount kit, fp red, injectors
or
Hi 330awhp,
What are your goals for modding?
Essentially you are getting the front mount and injectors with both set ups and th main difference is larger turbo (FP Red) or Camshafts.
You will need to fuel pump with the FP Red.
Because you said FP Red I will assume you are looking for high HP. In this case I would go BT(bigger turbo) and if you have the money install the cams in at the same time.
While the cams are a decent mod, I feel they would benefit more from a BT. Thus I would not worry about putting the camshafts on now. i would do it when upgrading turbo.
If you could provide more information we can give you a more specific answer
Also If you put the cams in first you will have to tune, and then when you but the FP Red in you will have to tune again. Vs going FP red and cams at same time then do one tune. Saves some $.
my $.02
my $.02
