Sponsored by:
Sponsored by: CARiD
need help
Old May 21, 2011 | 07:46 PM
chendu1280's Avatar
cant change gears (AT) after tail light install, please help
i just install some led taillights, and i started the car, the car starts and the light works. i tried to put it in reverse to c if the back up light works, but i cant put it in gear, i did step on the brake of course, but if felt like i didnt step on the brake and i cant change gear period.., why is this, need help, cant drive the car now
Old May 21, 2011 | 09:54 PM
tephra's Avatar
get a code reader... if the lights arn't working it will throw a code...
Old May 22, 2011 | 08:49 AM
HELPr's Avatar
Is it possible that the shifter is locked?
Ive not worked with the Automatic yet but it wouldnt suprise me to find that there is an electric circuit of some sort that will not allow the shifter to move unless the right criteria is met.
I would suggest trying to turn the vehicle off, putting the key in the On position and trying to change the gear selector.
Also, remove the tail lights you just installed and put the stock tails back in (shouldnt take more than 20 minutes or so). If your vehicle miraculously works after that, you can conclude that there is an issue with the product or the way they were installed.
Maybe adjust the title of your post to "cant change gears (AT) after tail light install, please help"
you may get better response with that.
Old May 22, 2011 | 03:22 PM
mattcanada's Avatar
You most likely need a load resistor for the LEDs, I know quite a few people who put LED tails on lancers had a similar problem and after they put the resistor on everything worked perfectly.
Old May 22, 2011 | 08:11 PM
chendu1280's Avatar
but after i put back the oem light...it still doesnt work
Old May 22, 2011 | 08:20 PM
JDMCT9MR's Avatar
Did you check your fuses? You could of possibly blown one.
Old May 22, 2011 | 08:21 PM
2005evo's Avatar
Pics?
Old May 22, 2011 | 08:36 PM
chendu1280's Avatar
which fuze?
Old May 22, 2011 | 10:03 PM
chendu1280's Avatar
found the problem..scratch this..
Old May 23, 2011 | 11:17 AM
Evostare's Avatar
You do know it helps to write out what the solution to the problem was after you find it right? It helps others who might have this issue down the road.
Old May 25, 2011 | 09:16 AM
cowboy14's Avatar
I suggest you to go professional ......
