What is causing this gas mileage lately? 150 miles/tank??
so lately my car has literally been getting about 160 miles per tank or so. The car is lightly modded (intake, exh, mbc), but even for a while with that stuff on it was normal.
-Im literally driving slow as possible to make it last..
-i went and had the AFR checked (it was fine)
My clutch is slipping a lot...would that reduce the MPG that much though?
Plllllz helP!
Plllllz helP!
I've seen instances where clogged/bad O2 sensors on various cars cause terrible gas mileage. Do you have a wideband installed? Is that how you had AFR checked or did a shop do it and hook up to stock O2 sensors?
whats even wierder is that on my MR i changed it to sport mode for pretty much all driving except freeway. i've been going from 180miles on a tank to about 230. it makes no sense to me, and sport is more fun to drive anyways. "on a tank" refers to the exact moment my gas light dings, not til empty.
Is there a shop up by you somewhere? I would check all hoses are spots you could have a leak, Do you have a test pipe? Maybe the cat is clogged? And I would take it to get tuned and ditch the zchip..
From: Standing at the edge of the gene pool with a flamethrower...
Did this guy ever find out what his problem was?
Im having the exact same problem. I went to getting 300-360 per tank to 150 or so.
Dang....
And until now this has been a flawless car with over 50,000 miles on it and driven all over the country, literaly-
Dang....
I'd highly recommend changing out the spark plugs. I had one destroy itself in under 50,000km took it exactly 46,000, two track days and 400 1:4 passes tho n a bad tune.
As stated check your a/f even tuned it could be running crazy rich. I was running 10s and was getting about what you guys are. I switched plugs retuned and now get easily 500km per tank making 340/360. If no cats, try plugs n af
