Sponsored by:
Sponsored by: CARiD
Anyone have FOG HID?
Old Aug 9, 2011 | 07:43 PM
genelee112601's Avatar
I got 3k hid fog also love the bright
Old Aug 9, 2011 | 08:25 PM
GiLizILL's Avatar
The bumper didn't have to come off on a 09 ralliart..?
Old Aug 9, 2011 | 09:14 PM
Yoo Shin's Avatar
I understand without an actual HID projector housing the projection and cut of isn't going to be clean, but how is the actual projection? Does the clarity look decent or is it just a washed out blur of bright light like the HID kits you see someone do on their 1994 Ford F150? (you know the ones, you have all seen them)
Old Aug 10, 2011 | 02:07 PM
HudsonFalcon's Avatar
Originally Posted by Optiblue
Prior to this digital ballast, I was running one of those more expensive yet cheaper quality 35W kits from China and I encountered a problem where one side would sometimes not turn on.
DDM's kits are from China as well.
Old Aug 12, 2011 | 12:52 PM
EvoX-11's Avatar
Originally Posted by Red Dragon
I am running VVME 55W 5000K HID Kit. You can get them on ebay. So far that have been running for 2 year and no problems. Great price point. They are very bright. The factory fog light hosing/reflector is really conservative (compared to other fogs), so the light output does not span out a large range.
http://www.ebay.ca/itm/Xenon-HID-50W...item3cae749a78
(these are the ones i have)
I recommend taking off the front bumper, to install them cause it make life alot easier and allows you to route the wires better. You dont need to remove the bumper, just recommended.
I recommend running the HID off a relay, especially if your going to run a 55watt kit. You can get relay kits on ebay that are plug and play, which makes it really easy to install.
55w produces way too much heat for fog light housing. It could easily burn the housing heck even catch on fire. I think you are pretty luck that you didnt catch anything on fire.
Old Aug 19, 2011 | 10:27 AM
doc mighty's Avatar
35W 3000k no problems here
Old Aug 19, 2011 | 11:20 AM
35W 4500K here and they match the OEM projectors perfectly. They light up the sides of the roads and directly in front of the car very well.
VWJETTY
Mar 26, 2017 12:07 PM
seven10
Mar 9, 2017 09:36 AM
CWBs05LancerES
Sep 17, 2016 07:13 AM
Virus1x
Apr 6, 2016 07:32 PM
impreza2darksyd
Jun 12, 2010 08:45 PM
