Sponsored by:
Sponsored by: CARiD
X trans issues
Old Aug 29, 2011 | 11:36 AM
Orodi's Avatar
X trans issues
I am purchasing an Evo X here shortly. The phone call got cut off but he mentioned something about reverse having an issue. Is there a common problem there?
Old Aug 29, 2011 | 11:45 AM
torian05's Avatar
Nothing about reverse that i know, but the x's are pretty known for having notchy gears, and also under too much torque, usually from launching hard too many times, im not sure if im explaining this right but i guess the diff pins get pushed out and crack the diff? Also the cmc is crap, nothing about reverse but those are the things ive heard of that have to do with the X trans.
Old Aug 29, 2011 | 11:58 AM
EvilRob's Avatar
X has no true reverse gear so sometimes you have to let the car roll and inch or double clutch before reverse engages other than that gsr 5 speed trans is great. Notchiness goes away when it warms up.
Old Aug 29, 2011 | 12:03 PM
Orodi's Avatar
Sorry new to Evos, what is the cmc?
Old Aug 29, 2011 | 12:05 PM
Orodi's Avatar
I figured it wasn't anything serious. I have had the 3rd to 4th a couple times to get the car in reverse a time or two lol.
Old Aug 29, 2011 | 12:07 PM
gsrboi80's Avatar
^ CMC=Clutch Master Cylinder
Old Aug 29, 2011 | 12:08 PM
Orodi's Avatar
Ok so now to hijack-ish my own thread. I beat the bag out of cars. What do I need to beef up. Not going crazy on the mods at all. Keeping it in the 350-400 area.
Old Aug 29, 2011 | 12:17 PM
torian05's Avatar
If your planning on driving your car hard you will probably need a new clutch at some point.
When you do its better do to all this stuff at once, you will probably want to do
Clutch, Flywheel, Diff pins, and Clutch master cylinder. Then you should be pretty set drivetrain wise to drive your car hard.
Old Aug 29, 2011 | 12:23 PM
RoMeIX's Avatar
If you are keeping it at 350 to 400 hp you will be fine on all stock parts for a while. If you want to be proactive, a new clutch would be a good idea, but I personally would use the stock clutch until it needed to be replaced.
Old Aug 29, 2011 | 12:28 PM
Orodi's Avatar
Yeah I pretty much just replace clutches with an aftermarket piece anyways.
►EvolutionX◄
May 20, 2015 09:30 PM
enragedpanda
Jun 9, 2013 08:00 AM
evotell
Apr 16, 2013 03:49 PM
MonacoGP
12
Apr 18, 2008 09:51 AM
Wangracing
16
Dec 26, 2006 05:33 AM
