Sponsored by:
Sponsored by: CARiD
Gears Grinding a little
Old Sep 9, 2011 | 07:30 AM
armysoldier1073's Avatar
not difficult at all, will need a fluid pump. makes it easier..... about 2 on scale....
Old Sep 9, 2011 | 07:43 AM
Alpha X's Avatar
Yea I got in contact with a local performance shop that works with only EVO's and STI's and they will only charge me $35.00 plus the cost of the fluids
That beats $75.00 from the Mitsubishi dealer. Thanks for all of your help guys and I will let you know if it fixed the notchy noise
Old Sep 9, 2011 | 07:59 AM
Supraboy1's Avatar
Originally Posted by Kilo Evolution
On a scale of 0-10 how difficult is it to do on your own?
0 being a 90 year old granny could do it and 10 being very difficult
*Replacing my manual transmisson fluid with new fluid
Called my local Mitsubishi dealer and they want to charge me $75.00 for the labor >__>
$75 isnt not bad. If they do it and there is a problem later its documented. But if you do it.. Its about a 3 on difficulty.
Old Sep 9, 2011 | 08:01 AM
Kracka's Avatar
Originally Posted by armysoldier1073
Redline fluids came out recently with a MT-85, on site recommends it for the Evos.
That is not the correct fluid, MT-85 was designed for the Evo 1-9 and DSM. The X uses a slightly different viscosity.
Old Sep 9, 2011 | 08:06 AM
Ahhh.... didn't see that. It just stated evolution. didnt mean to provide false info.
Old Sep 9, 2011 | 01:22 PM
Sev's Avatar
Sev
It's normal in X's. Mine constantly clunk-grinds to 3rd. Not as bad in 2nd or 1st though.
Old Sep 9, 2011 | 02:23 PM
jeffo24's Avatar
This is completely normal, i think. When i first got my EVO i was also novice at manual, and i had the exact same problem; did some searches; thought my synchro's were bad, bla bla.... well now that i'm fluent at driving manual it doesn't happen anymore. It was all in the way i was shifting and how i 'angled' the stick, if that makes any sense.
i found that when shifting from first to 2nd, instead of pulling straight down on the stick, i was trying to actually pull down and LEFT, which caused it to grind. Pull the stick straight down and it'll be a solid smooth motion. Same with 3rd. Shift in one solid fluid motion.
This was my case, hopefully it helps.
Old Sep 9, 2011 | 02:30 PM
JonU's Avatar
Not having owned an Evo, I would have to agree with the majority saying it's normal. I would be very very surprised if you wore out the synchro's in just 7200 miles. Just sounds like a quirk of the transmission. I know on my Z it likes to make a clunking noise when coming out of first and going into second.
Old Sep 9, 2011 | 04:15 PM
evokur's Avatar
^I had a 03 Z that did the same thing...going into 2nd was annoying.
Anyways thanks for the info on the Redline Cocktail. I'm going to try this on my '11 X. I have 300 miles on it now but it was notchy to begin with when I drove it off the lot 2 weeks ago.
Now I'm off to the Ultimate Rattle Thread. Yes, my X is rattling and driving me crazy at only 300 miles!
Old Sep 9, 2011 | 07:01 PM
S2K2EVO's Avatar
Originally Posted by Kracka
His synchros are fine, this is normal.
2 quarts of Redline MTL + 1 quart of Redline MT-90 fluid
Plus whatever brand of transmission/shfiter bushings you prefer; I have WORKS, but Torque Solution, AMS, TWM, etc. all make them too. I also have a WORKS short-shifter. All together it makes for a wonderful package, my X is the 2nd best shifting car I've owned after my S2000.
The S2000 transmission is amazing! I always look forward to something that will be as good. The 350Z was not as good with its 6 speed. When I do get an EVO I will see how it compares to those two.
d-sport
Oct 27, 2016 11:51 AM
9!'clipseDOHC
Jul 7, 2015 05:25 PM
ArchieBabes
17
Feb 16, 2013 06:11 PM
jameswwt
10
Sep 18, 2011 12:53 PM
pb91
Jun 8, 2011 02:44 PM
