Sponsored by:
Sponsored by: CARiD
11 Evo X Reg: shifter need help
Old Oct 12, 2011 | 06:05 AM
04Evo851374's Avatar
Hey everyone I was checking out some shifter bushings and some other stuff to see what will help make the shifting on these cars better, cause the stock shifter doesnt feel good and every time you put it on 3rd it does that sound like a grind, it doesnt grind but that sound which i know most of you realized it already.
What do you guys recommend, should i go with the kit from TWM the shifter base, cable and transmission arm bushing kit combo from them ?
Is all of that needed and will that resolve the switching to 3rd issue or not.
Please if someone could help me out here.
Thanks
Old Oct 12, 2011 | 06:26 AM
Kracka's Avatar
https://www.evolutionm.net/forums/ve...led-evo-x.html
https://www.evolutionm.net/forums/ve...t-shifter.html
Old Oct 12, 2011 | 08:17 AM
Thanks
Old Oct 12, 2011 | 12:40 PM
dyss.'s Avatar
just bought these and my shifter can't wait to feel the difference when i get back
Old Oct 12, 2011 | 12:51 PM
No_Skillz's Avatar
The solid base bushings and the metal underhood bushings and transmission arm bushings make the biggest difference. No need to change the actual shifter unless you want it lower/shorter.
Old Oct 15, 2011 | 03:05 AM
Naco's Avatar
You might also want to try the free fix of adjusting the shifting cables to your liking. I found this made the biggest difference in shifting quality.
Old Oct 15, 2011 | 05:40 AM
Alpha X's Avatar
Would it be better to get the whole cage replaced or is that not necessary?
Old Oct 15, 2011 | 07:14 AM
Im going with that then, Thanks
Old Oct 15, 2011 | 04:01 PM
No_Skillz's Avatar
Not necessary.
Old Oct 15, 2011 | 04:30 PM
Kracka's Avatar
I should be getting one for testing, stay tuned...
Old Oct 15, 2011 | 04:51 PM
user 629782012's Avatar
In my opinion the best shifter + bushing and underhood bushing set on the market is TWM, I've had 3 of their sets over the years. they all performed flawlessly!
http://www.twmperformance.com/shorts...rtshifters.htm
`$184.95
I will also say that the customer service is awesome. as i installed one of thier kits in my old car i snaped one of the oem parts of my car. the dealership couldn't help me but TWM did. TWM shipped out a part for me right away free of charge. I had the part in about 24 hours.
Also found another one
Thanks
TheIndianGuy
Oct 25, 2016 11:20 AM
Kreeker
Feb 5, 2016 01:52 PM
pb91
Jun 8, 2011 02:44 PM
LeeC
Apr 17, 2010 10:00 AM
rsboy
Oct 20, 2005 09:26 AM
