Sponsored by:
Sponsored by: CARiD
Aem afr gauge
Old Nov 4, 2011 | 09:22 PM
Panda_stunter's Avatar
Aem afr gauge
So I finally have my afr gauge installed. I was monitoring it while I was driving earlier and for some reason, the afr sometimes is at 15. And when I'm driving it goes off the range...meaning it goes way lean. I see that it goes lean when I'm just coasting.
Ok, here's a scenario. 5th with gas or throttle position constant, it's at around 11-12, but I take my foot off the gas pedal, it goes red and doesn't show up the reading. Or, when I'm driving I just coast, the rpm goes down, then when the mivec cuts off, the afr does the same thing, goes red and afr doesn't read.
Is this normal?
WOT, it's at 10-11. So I'm not that worried about that.
Long story short, I should only be worried about lean conditions when I put load right?
Old Nov 4, 2011 | 09:29 PM
occxlr8ed's Avatar
pretty much the same as mine......got mine installed with my e85 build on wednesday and noticed the same thing.
i trust my tuner though but i guess i'll bring it up with him to be safe
Old Nov 5, 2011 | 12:46 AM
mp72's Avatar
It's normal and the afr gauge does that when you take your foot off of the gas pedal. I forget why, but that's what I was told after I had my AEM afr gauge installed.
Old Nov 5, 2011 | 08:24 AM
Carvs's Avatar
^ +1, same thing on my end as well
Old Nov 5, 2011 | 08:42 AM
Snakes709's Avatar
thats normal. When you let off the gas, the engine isnt taking any fuel or air, so your sensor isnt reading anything in your pipes.
Do you have a tune? im still on stock tune and when im wot my wideband reads 10 flat at 5000rpm, so by the time its at 7000rpm its in the 9's...which is normal. Just wondering if u have a tune since u r around the 11's at wot.
Old Nov 5, 2011 | 09:55 AM
TheBlade's Avatar
As people are saying, totally normal. Sounds healthy. Here's what to watch for:
1) WOT (sounds like you're seeing it healthy now anyways)
2) Partial throttle load conditions ( 11-15 isnt bad, remember 14.7 is stoichiometric for gasoline)
3) idle. Idle shouldn't creep up, and stay above 15.5 or so. You'll always see it oscillate a little and that's normal, but you're looking for it persisting up high.
@Snakes709
9:1 A/F is TOO rich even for WOT (for gasoline, not quite rich enough for E85). X's have a terrible factory tune on the error side of rich, but it can wash walls. If only Mitsu could approve people getting their X's tuned to fix the broken factory tune
Old Nov 5, 2011 | 11:18 AM
@Snakes709
WOT, it's 11-12, sometimes 10. I watched it again last night.
Partial, it's at 13-14
Idle, it goes 15.5
The only tune I have is Cobb ap OTS map. Stage 2 acn 91.
Old Nov 5, 2011 | 11:22 AM
TheBlade's Avatar
Idle, it goes 15.5
then the OTS is looking healthy for your car.
Old Nov 5, 2011 | 12:30 PM
Intellex's Avatar
@Snakes709
Pretty much hit it spot on.
Old Nov 5, 2011 | 03:50 PM
santeller's Avatar
im running the ams stage 2 ots map and my gauge always fluctuates up and down but idle is roughly 14.8 or so and wot is about 11-11.5.
Old Nov 5, 2011 | 04:07 PM
stEVOrgiX's Avatar
Good stuff Santeller. WOT shouldn't be leaner than 11 otherwise you're getting into vent block territory.
Old Nov 5, 2011 | 09:30 PM
Snakes709's Avatar
@Snakes709
Exactly, the evo's enemy is the sti which pushes out like 14hp more? If mitsubishi changed the tune a tiny bit and made it abit leaner...im not saying make it 11.9-12.0 at WOT but like 10.5-10.8 that will give it the bit more power to match the sti.
Old Nov 6, 2011 | 11:29 AM
TheBlade's Avatar
Yeah, my previous car was a 05' STi that I had tuned from a local tuner I like. Personally I think the only reason the STi feels faster, is the torque from the 2.5L. Just "feels" more impressive. Also, the turbo on the STi just lags a little more. The EvoX's boost comes on really smooth.
Old Nov 7, 2011 | 07:09 PM
phishy's Avatar
After boosting my gauge reads high reds then calms down and settles. I'll look @ it next time im @ wot. I'm STAGE3 tuned though so readings maybe a bit off.
Old Nov 8, 2011 | 07:13 AM
Widoww's Avatar
Idle 15-15.5
Off gas goes red like everyone
Wot is 11.2-11.5
