Sponsored by:
Sponsored by: CARiD
basic bolt on power
Old Nov 23, 2011 | 07:59 PM
ravenjam's Avatar
Originally Posted by cla2000
I dont think that's right. If i remember correctly a 2011 puts close to 280 at the wheels in stock form.
highly unlikely as crank HP is rated at 291HP. I know there have been improvements in the 2011, but i dont think only a 6% power loss in the transmission is one of them.
Old Nov 23, 2011 | 08:07 PM
ityn's Avatar
Originally Posted by ravenjam
highly unlikely as crank hp is rated at 291hp. I know there have been improvements in the 2011, but i dont think only a 6% power loss in the transmission is one of them.
+1
Old Nov 23, 2011 | 08:13 PM
toomanytickets's Avatar
not it stock form it wouldnt, you would need around 350-365 at the crank to put out 280whp
Old Nov 23, 2011 | 08:53 PM
menasor's Avatar
Stock 2011 X puts down 260 whp. Cobb has a dyno graph of this. Compared to an 08 X that put down 220 whp on their dyno. We all know the 291 crank hp number is highly underrated
Old Nov 24, 2011 | 03:09 PM
EvoXPhantom's Avatar
Originally Posted by mct9891
dont evo's come stock with that much?
+1 I was about to say the same .
Old Nov 24, 2011 | 05:26 PM
tehSteve's Avatar
I bet a case of beer if you were to take a stock X '08 and flash it with the stock X '11 map you would see that extra 20+whp on the dyno.
It's just that now the '11 people are comparing their baseline to their tuned runs & end up seeing less of a whp gain than us people in the lower generations of the X after we ended up getting tuned with the same Stage2 setups.
Ultimately it doesn't matter because regardless a good tuner will be able to fix that mitsu 20whp difference when tuning time comes
Old Nov 24, 2011 | 08:17 PM
phishy's Avatar
Originally Posted by phi79
330whp???
Probably this on 93
Old Jan 27, 2015 | 08:28 PM
White_Evo10's Avatar
Originally Posted by EVO X 6950
full bolt ons, check sig. the high flow will hold you back
Why would the cat hold him back?
Old Jan 27, 2015 | 08:38 PM
BiHBeast's Avatar
365/400 on e85 with bolts on and stock downpipe and turbo. 400 might seem like a lot of tq, but this is in denvers altitude so it's actually lower.
Old Jan 28, 2015 | 05:02 PM
elkazX's Avatar
woah. you definitely will not be seeing 400wtq, if you do, you better have a built block or your **** will blow up depending on how you drive it. 400 torque is a lot for a stock block, and it definitely isnt safe. I have those mods that he has, just different brands, but on 91 i made 355whp and 310wtq.
Old Jan 28, 2015 | 11:05 PM
stinowevox's Avatar
i think around 310-330.. 350 is too much for just bolt-ons unless you're going e85
Old Jan 29, 2015 | 07:41 AM
BiHBeast's Avatar
Read my post again, I'm in denver, where there's a lot of altitude. Not the same numbers @ sea level
Old Jan 29, 2015 | 03:19 PM
elkazX's Avatar
i made 355whp on 91..people have told me from experience they make around 400whp on e85
Old Jan 30, 2015 | 09:35 PM
stinowevox's Avatar
oh thats good on 91! how much boost??
Old Jan 31, 2015 | 08:54 AM
elkazX's Avatar
yeah i was surprised! but 26psi
