Sponsored by:
Sponsored by: CARiD
Blue smoke
Old Nov 30, 2011 | 09:33 AM
EvoForumUser12's Avatar
Blue smoke
So on the way to Costco today I see blue smoke in the exhaust as well as the usual black. The blue smoke is only produced on heavy/WOT, and disappears as soon as I let off. The car threw a cylinder 4 misfire code about 2 weeks ago. The code did not re-appear after a plug swap. So how much $ am I paying to play this time
Old Nov 30, 2011 | 09:37 AM
Boltz.'s Avatar
FCOTM Winner
Burning oil...
Bad rings, bad turbo seal?
Old Nov 30, 2011 | 09:41 AM
Vivid Racing's Avatar
Originally Posted by Boltz.
Burning oil...
Don't give the man a heart attack just yet
It could very well be your PCV system, which would be cheap. It could be your turbo, or rings, or valve seals. Start with checking the PCV system, then do the leak down test. If it's only at WOT and doesn't even happen every time, you've got a ways to go before things go boom. If you need any parts, let me know. We've got OEM stuff too.
Old Nov 30, 2011 | 11:03 AM
jordantii's Avatar
And how do you check the PVC system? Never mind I found it in the service manual 17-71.
Old Nov 30, 2011 | 11:11 AM
Boltz.'s Avatar
FCOTM Winner
Good point. I overlooked the thought of the PCV system.
Old Jan 11, 2012 | 06:22 PM
Had Ivey Tune look at it. The tests showed no problems - they changed the plugs and everything has been fine since.
W0LF
17
Sep 1, 2017 12:40 PM
Lil Evolution X
Oct 27, 2015 05:30 AM
Markley02
30
Jun 13, 2008 07:43 PM
1QYK9
64
Feb 29, 2008 09:39 AM
PEOPLExpress
Oct 20, 2005 06:49 PM
