Sponsored by:
Sponsored by: CARiD
faulty clamp?
Old Dec 3, 2011 | 09:11 AM
johnvan29's Avatar
faulty clamp?
Hey guys, I am installing a new uicp from ams and cannot get the clamp from the uicp to turbo outlet to loosen and it is worrying me a little bit... any suggestions?
Old Dec 3, 2011 | 09:18 AM
CurseDSM's Avatar
I'm confused, you say uicp to turbo outlet? Wouldn't that be the lower ic pipe? Or is the X different? On the clamp though what are you using to try to get it off? I always try to use a socket and it it just spins like that stick a screwdriver (flat head) under the bolt on the clamp and try to unscrew it again. By doing this your actually makeing it tighter so it should grab some.
Old Dec 3, 2011 | 09:19 AM
johnvan29's Avatar
turbo outlet to UICP sorry just had order mixed up, problem is faulty clamp
Old Dec 3, 2011 | 09:28 AM
CurseDSM's Avatar
No I realized that. I just wanted to make sure I understood. Give what I said a try it should give it enough to bite on and back the clamp off. If not then man your in a world of **** sorry brotha.
Old Dec 3, 2011 | 01:47 PM
johnvan29's Avatar
AHH thank you so much it finally worked!
Old Dec 3, 2011 | 01:58 PM
CurseDSM's Avatar
Glad I can help. I was worried you wouldn't understand what I was saying about putting the screwdriver under the nut and giving it something to grab on
stefenboy
Jan 4, 2017 12:17 PM
Crosxs
Jul 8, 2016 08:34 PM
mygsx
Feb 20, 2016 07:08 PM
AJCaron12
Apr 8, 2012 08:30 AM
tpdc2
May 24, 2010 06:23 AM
