Sponsored by:
Sponsored by: CARiD
Shift from normal to sport
Old Dec 3, 2011 | 07:27 PM
mitlan's Avatar
Is that I can only shift from the SST normal to sport while stopping? This is what I see from the user manual. Can I shift during driving. It is weird if I can't shift it whenever I need it during driving like passing someone or going uphill .
Old Dec 4, 2011 | 04:21 AM
Cat's Avatar
Cat
You can go from normal to sport on the road. You have to stop to shift into s-sport.
Old Dec 4, 2011 | 06:39 AM
Widoww's Avatar
Why you need to use sport to climb a hill? Just downshift to 5th lol..sport can be used at any speed.
Old Dec 4, 2011 | 08:24 AM
sailing217's Avatar
change at any speed
Old Dec 4, 2011 | 09:09 AM
tnn35's Avatar
need to pass someone? down shift 1 or 2 times, press the gas .
Old Dec 5, 2011 | 06:07 PM
lil ayzian's Avatar
u can always switch from normal to sport. change the awd configuration anytime as well
Old Dec 5, 2011 | 08:53 PM
mitlan's Avatar
Well, I just give some examples for using the sport thing. I don't go racing, so the only chance for me to play with it are the situation that I have mentioned. But if you guys have more suggestion on how to play with it, feel free to type here. Thank you
Old Dec 6, 2011 | 12:53 PM
jrz's Avatar
jrz
I tried the manual, how do you set the launch control?
Old Dec 6, 2011 | 01:44 PM
highlyevolved's Avatar
You can use the paddles to down shift when passing or on a hill. Sport is only really useful if you want all shift points to be more aggressive. It also is supposed to improve throttle response but I haven't really noticed a difference.
Old Dec 6, 2011 | 06:38 PM
daleks's Avatar
I used Sport often when going at low speeds. I find otherwise the transmission jumps around across too many gears. When puttering through a parking garage or moving in stop & go traffic I find this to be the case.
Old Dec 6, 2011 | 06:49 PM
The__J__Factor's Avatar
I drive 100% of the time in sports full manual mode.
Normal mode = too much slip/slow changes/not as responsive.
Old Dec 6, 2011 | 09:00 PM
adean12's Avatar
I also do this.
Old Dec 7, 2011 | 08:04 AM
Thanks for the tip about using S mode for stop and go. Makes perfect sense how it might smooth out the shifts when puttering compared to the super aggressive upshifting of N.
Old Feb 13, 2012 | 11:47 AM
duffmangt's Avatar
I was wondering the same thing, thanks for the info. Hopefully driving in sport in rush hour will help the constant jerky shifts of normal mode.
Old Feb 13, 2012 | 03:11 PM
daspasian's Avatar
Still wish we could change it to S-Sport mode while on the go...
