Sponsored by:
Sponsored by: CARiD
anyone else leaking brake fluid?
Old Dec 13, 2011 | 09:11 AM
acm_evo's Avatar
Hello,
while doing an oil change the other day, I noticed that my '10 MR has been leaking brake fluid. I did not remove the lower tray to see where the leak was coming from, but from what I was able to see, it's not leaking from the master cylinder area. Also, the bottom of the transmission and engine area is bone dry. I was able to inspect those areas through the little holes on the tray, as well as from the removable access panel. I see a little brake fluid dripping from the tray, which along with the brake warning light and low fluid level indicated this is not imaginary. I'm dreading to take the car to the local dealership, but i guess I don't have any choice at this point, since i don't want to tackle a job covered under warranty. Has anyone else experienced this same issue with their car? Searching the forum, there are quite a few threads about brake warning light coming on, and everyone seems to think that it's simply due to the brake pads wearing thin and the consequent drop in fluid level in the reservoir (just like I did at first), but has anyone actually confirmed that they had no brake fluid leaking anywhere? With the engine tray in place, it may take a while before actually seeing traces of brake fluid on the ground...
Also, any recommendations on what dealership I should be taking my car in? Around my area, the only dealership for miles is Capitol Mitsubishi. Is their service dept. any good?
Thank you.
Kainvorador
Feb 4, 2018 09:12 AM
JIMMY_HIPPO
Jul 13, 2015 07:02 PM
grahamab
23
Aug 12, 2013 12:15 AM
spyghost
Lancer How Tos / Installations
Aug 8, 2013 11:00 AM
denon728
Jul 26, 2006 09:27 AM
